19 June 2024
KtoA 4.3.2.1 uses Arnold 7.3.2.1 and is a bugfix release.
Installation
Katana 4.5 and 5.0 compatibility
Katana 4.5v3 and 5.0v3 introduced a change that affects the Arnold USD plugins support in Katana. This release of KtoA supports those Katana versions or newer within their release series. Katana 4.5v1, 4.5v2, 5.0v1, and 5.0v2 are not supported by this KtoA release.
Bug Fixes
ARNOLD-14365 - Fix AiNodeGetMatrix to return node matrix instead of identity after node initialization in batch renders
ARNOLD-14779 - AtProfiledLockable not compiling on Windows in newer MSVC due to Mutex::native_handle_type
ARNOLD-14893 - [GPU] 4MB GPU memory leak per frame
ARNOLD-15041 - Arnold does not run on Linux distros with glibc 2.39 (RHEL 9.4)
ARNOLD-15048 - Fix OIDN dll name clash with DCCs by renaming OIDN libraries
ARNOLD-15060 - Arnold should not catch C++ exceptions it did not generate
ARNOLD-15087 - uv_projection shader uses corrupt UVs for evaluating its default_color shader
ARNOLD-15121 - [GPU] crash when CUDA error has no message
ARNOLD-15122 - Crash destroying a light that is part of a light group
ARNOLD-15136 - Random hang when parallel initializing scene
ARNOLD-15169 - Crash when modifying a child node from procedural_update
usd#1923 - Fix instance primvar indices with multiple prototypes
usd#1929 - Ensure subdiv_iterations is not set unnecessarily during procedural updates
usd#1932 - Fix a crash when the number of elements in a primvar is not equal to the number of points
// Stephen Blair
// Arnold Renderer Support
