Show only
Search instead for
Katana 4.5v3 and 5.0v3 introduced a change that affects the Arnold USD plugins support in Katana. This release of KtoA supports those Katana versions or newer within their release series. Katana 4.5v1, 4.5v2, 5.0v1, and 5.0v2 are not supported by this KtoA release.
Enhancements
Global light Sampling support on GPU:Global Light Sampling (GLS) is now available with GPU rendering. Many scenes with moderate to large number of lights render 2-6x faster with GLS. Scenes that do not benefit from GLS tend to be a few percent faster or slower. See theGLS documentationfor important information on the optimal number of light samples to use with GPU. (ARNOLD-13109)
Speedup over 7.2.2 GPU version using 1 light sample
City (100000 lights)
Classical interior (80 lights)
Automotive studio (9 lights)
48x speedup
2x speedup
2.6x speedup
Multi-channel render outputs: You can now render multi-channel EXRs and TIFFs by selecting more than one output channel inRenderOutputDefinenodes. Note that for preview and live renders only the first output channel is shown in the monitor for the render output, but for disk renders all output channels are rendered in the same file. (KTOA-898)
Multiple shader outputs improved support:
state_float,state_int,state_vectornow have multiple outputs: Thestate_*shaders now have multiple outputs, so you can use a single state shader with multiple output connections in a shading network. (KTOA-894)
Traditional out port: Shaders that have multiple output ports but also have the traditional "out" port will show both. (KTOA-905)
ArnoldIn and UsdIn import of multiple outputs: Both import nodes properly handle shaders connected to others with multiple outputs. It is still required that the root shader of a network provides the traditional "out" port, however. (KTOA-905)
Pixel probe picking mode for instances: By default, picking an instance in the monitor now picks the instance location instead of the instance master location. You can go back to the old behavior using the new ArnoldGlobalSettings > Debug Settings > Picking option. (KTOA-886)
Disable GUI for analytics and error reporting in batch mode: KtoA now explicitly disables any dialog boxes that could have popped up when Katana was running in batch, shell, or script mode. (KTOA-897)
Return direction and distance to nearest hit in distance shader:Arnold 7.2.3 addsout_distanceandout_directionoutput parameters to the distance shader, which return the direction and distance to the nearest surface, respectively. The shader still returns the color-mapped result by default, which is now available as theout_rgbparameter. (ARNOLD-13473)
distance shading effect
Tutorial - Building facade fire damage
Tutorial - Eye makeup shading effect
state_float, state_int, state_vector multiple outputs:The shading state shaders now have multiple outputs, so you can use a single state shader with multiple output connections in a shading network. (ARNOLD-13579)
USD Enhancements
Support vertex UV coordinates on Curves in the render delegateusd#1435
Curves without width should render with a default valueusd#1579
API Additions
AiProceduralExpand: A new APIAiProceduralExpandexpands on demand the contents of a procedural (such as a 'usd', 'alembic', or 'procedural' node), as it would happen in a regular render. You can use this to force the creation of procedural child nodes before the rendering starts, and to avoid race conditions when the procedurals are not thread safe. (ARNOLD-7067)
Bug Fixes
KTOA-880 - Curves that render in Solaris do not render in Katana
KTOA-881 - UsdIn sets output ports incorrectly
KTOA-883 - Vertex ordering differs between UsdIn and ArnoldIn
KTOA-884 - Invalid warning about live render differing shaders
KTOA-886 - Pixel probe in monitor does not pick instances
KTOA-887 - Vertex scope and uniform int user-data on curves not handled correctly
KTOA-890 - UsdIn enum shader parameters sometimes wrong type and value
KTOA-893 - Subdiv type not set correctly from UsdIn
KTOA-896 - Subdivision type set to invalid value from UsdIn
KTOA-909 - UsdIn arnold-specific subdiv type and other object settings erroneously overridden by mesh subdivision scheme
ARNOLD-10643 - FIS no longer forces a box filter
ARNOLD-12917 - Viewport API uses incorrect motion blur reference time
ARNOLD-13645 - Instancer crash if a single node is instanced but set to null
ARNOLD-13678 - Holes in alpha channel when opacity is almost 1
ARNOLD-13741 - Log messages missing colors
ARNOLD-13770 - Name scope clashes with nested procedurals
ARNOLD-13776 - NaNs when using global light sampling with low-light-threshold
ARNOLD-13789 - Corrupted tiff output if skip_alpha and unpremult_alpha are both enabled
ARNOLD-13908 - Windows and macOS license failures with single-user and network Arnold licenses
Windows 10 or later, with the Visual Studio 2019 redistributable.
Linux with at least glibc 2.17 and libstdc++ 4.8.5 (gcc 4.8.5). This is equivalent to RHEL/CentOS 7.
x86-64 CPUs need to support the SSE4.1 instruction set.
GPU rendering works on Windows and Linux only and requires an NVIDIA GPU of the Ampere, Turing, Volta, Pascal, or Maxwell architecture. We recommend using the525.89 or higher driverson Linux and528.49, or higheron Windows. SeeArnold GPUfor more information.
For GPU rendering, the cache also needs to be re-populated after installing a new Arnold version,updating to a new NVIDIA driver, or changing the hardware configuration of GPUs on the system. More information can be foundhere.
