Arnold for Katana Forum
Rendering with Arnold in Katana using the KtoA plug-in.
Does KtoA support interactive xgen?
5 REPLIES 5
Mr.baiking
670 Views, 5 Replies
KtoA support classic xgen with .xgen file,but is it possible to support interactive xgen?
Tags (1)
Labels (1)
5 REPLIES 5
ben.fischler
in reply to: Mr.baiking
I don't believe it is currently, but this might be a question for @Mike Farnsworth.
I don't believe so. KtoA's XGen support is based purely on the procedural plugin, which only runs once at the beginning of the render. Dynamic modification of the procedural contents would not be reflected inside of Katana. Interactive modification and look development of XGen assets should be performed in Maya, and then brought into Katana via KtoA for final scene assembly, lighting and rendering.
Thanks Mike,so the only way is to export interactive xgen to abc cache ?
@Mike Farnsworth It is unclear to me whether an ArnoldXGen node will also work for inputting interactive xgen .abc cache files. At least, I have not had luck doing so. Can you please verify this?
Just curious if anyone has been able to render interactive xgen caches in Katana? From what I gather so far from forums (Autodesk, Foundry, and this one) is that interactive xgen isn't treated the same way as the legacy xgen.
If I bring interactive xgen caches into katana via an Alembic_In node I get a scene graph location for the xgen of type "curves". This shows up in the viewer but does not seem to be getting rendered.
I don't see any warnings suggesting an issue with the inputs.
Anyone able to share in their success?
Technology Administrators
