Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
USD SKELETON
12 REPLIES 12
Message 1 of 13
nickwebber
850 Views, 12 Replies
USD SKELETON
I have created a crowd sim in Houdini and it renders fine with arnold/solaris. But when rendered as a procedural the characters arn't deformed.
Any ideas?
Thanks!
Tags (1)
Labels (1)
  • USD
12 REPLIES 12
Message 2 of 13
andreskluge
in reply to: nickwebber
not working here as well unfortunately...
Message 3 of 13
julian.hodgson
Please try HtoA 5.3.0 (https://docs.arnoldrenderer.com/display/A5AFHUG/HtoA+5.3.0), as this should be fixed in usd#329.
Message 4 of 13
andreskluge
yes, using htoa 5.3.0
Message 5 of 13
julian.hodgson
Can you share a simple scene showing the setup you are using so we can take a look please?
Message 6 of 13
andreskluge
and just like that it starts working! turns out if you are at a wrong frame, it does not give an error, but just shows all the agents in the t-pose, giving the impression that its not working.
but i wanted to clarify - is arnold able to take any advantage of the fact that i have a single agent in a crowd of 100 thats been deformed? Any sort of instanceing that can use the skeleton data to deform the same polygonal shape?
Message 7 of 13
pal.mezei
in reply to: andreskluge
Hi Andres!
There is no instancing used for crowds as of now, due to each agent potentially having a different geometry to others.
For example, when rendering inside Solaris, we receive each agent as a separate polymesh. We could potentially keep track of the geometry information, and using some smart hashes. Identifying the meshes that share the same underlying geometry, only use object space subdivision settings, no world space/instance dependent displacement and so on. For now we are not doing any of this, as it can get very complicated quickly.
Cheers,
Pal.
Message 8 of 13
andreskluge
in reply to: pal.mezei
thanks a lot for the explanation. makes sense.
Message 9 of 13
nickwebber
It must be no? I had a scene with hundreds of of agents and only one frame was 10 meg
Message 10 of 13
nickwebber
Ah just saw the reply.
Message 11 of 13
julian.hodgson
Good to know about the frame range issue - glad it's working.
With respect to the sharing of polygon data between similar agents, we have the core ticket 7773 to look at this.
Cheers,
Julian
Message 12 of 13
nickwebber
Hi how can we send a scene? Arnold crashes for me. Latest version.
Message 13 of 13
pal.mezei
Please send the scene to support@arnoldrenderer.com and mention this post in the email, so we know which question the support request relates to.
