Urgent really need help cant render
Message 1 of 16
Hello I need to render a flip sim in a matte whit arnold but when I put the sim on arnold crashing !!
In the log I have nothing, and in the older log I have this message
00:00:00 3684MB ERROR | signal caught: SIGSEGV -- Invalid memory reference
https://vimeo.com/510307450/6c2d89ba5f
Replies (15)
Message 2 of 16
Stephen.Blair
I can't tell anything from the video.
Can you strip down the scene...is it just the one thing that crashes?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 16
julian.hodgson
Also, if you start houdini from the command line, and change Log Verbosity to Debug and increase the Max Warnings to a high number, do you see anything else in the log?
Message 4 of 16
I need to explain I have a sim fluid if my sim fluid is disabled I can render, if I activate my sim arnold crashes
I have already renderer my sim whit mantra, but now I need to render my boat whit arnold and put my sim in matte but in matte or alone Arnold crashes
and when I make a new geo node with a file cache loading my sim I have the same result
but I need to have the sim in matte for my final compositing in nuke
Message 5 of 16
I don't know to do this
Message 6 of 16
brian_Foley
For Mac and Linux the command line is Terminal.
The Log Verbosity and Debug can be found in the Arnold ROP - Diagnostics
Message 7 of 16
Here is the log log2.txt
Message 8 of 16
here is the log log2.txt
Message 9 of 16
Stephen.Blair
That looks like everything stopped during scene translation (when HtoA reads the Houdini scene and converts to Arnold data). Possibly on this object: /obj/guidedoceanlayerleopold_fluid_extended
How do I reproduce this? What do I create in Houdin? Or can you provide a simple scen that reproduced the problem?
// Stephen Blair
Message 10 of 16
yes you can try with ocean layer guide on the shelf tool
i make a render at this time, if i can i give you a link to download all my project (without cache file )
Message 11 of 16
or just my cached file and load it in a geo
i make this in an a hour or two
Message 12 of 16
download this file cache and try it on a geo node whit a file node arnold will crash https://www.myqnapcloud.com/smartshare/6g9f4lh44l6p709560y86z67_6lBAReh
Message 13 of 16
brian_Foley
Yes, it crashed on first render for me. I added a clean node with Remove Degenerate Primitives on and it rendered without any issues.
Message 14 of 16
Hello i have found how to render i explain how later when my render finish
Message 15 of 16
julian.hodgson
If this is crashing for a certain piece of geometry e.g. the fluid wake, can you please upload the file so that we can look at the fix?
Message 16 of 16
Hello here is the problem on guided ocean layer if you put a file cache and load it arnold and houdini crashes
but if you dont do it you render time take more time with the file cache i save 2hrs
I edit the problem is not the cache file is the delete node if you made a cache without the delete node no problem
