Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
procedural usd and uv-s
1 REPLY 1
andreskluge
386 Views, 1 Reply
hi,
it seems to me that arnold procedural does not support the uv-s coming from solaris. the issue seems to be the data type - as houdini by default reads in the uv data as "texCoord2f" but arnold expecting a regular "float2". theres an easy workaround but wanted to check if im doing something wrong or is that the case?
br,
andres
Labels (5)
1 REPLY 1
pal.mezei
in reply to: andreskluge
Hi Andres!
No, you are doing everything correctly, this is a bug in the procedural. I created a ticket for your issue https://github.com/Autodesk/arnold-usd/issues/463 and submitted a fix too https://github.com/Autodesk/arnold-usd/pull/464 .
Thanks for reporting this!
Cheers,
Pal.
Technology Administrators
