Apologies,
channel list: R, G, B, A, N.R, N.G, N.B, P.R, P.G, P.B, RGBA_LIGHT_PRP_01.R, RGBA_LIGHT_PRP_01.G, RGBA_LIGHT_PRP_01.B, RGBA_LIGHT_PRP_01_variance.R, RGBA_LIGHT_PRP_01_variance.G, RGBA_LIGHT_PRP_01_variance.B, denoise_albedo_noice.R, denoise_albedo_noice.G, denoise_albedo_noice.B, emission.R, emission.G, emission.B, motionvector.R, motionvector.G, motionvector.B, specular.R, specular.G, specular.B, specular_variance.R, specular_variance.G, specular_variance.B, sss.R, sss.G, sss.B, sss_variance.R, sss_variance.G, sss_variance.B, transmission.R, transmission.G, transmission.B, uv.R, uv.G, uv.B, variance.R, variance.G, variance.B, variance.A
arnold/AA_samples: 3
arnold/AA_seed: 1650
arnold/aovs/denoise_albedo_noice/filter: "gaussian_filter"
arnold/aovs/denoise_albedo_noice/filter_width: 2
arnold/aovs/denoise_albedo_noice/lpe: 1
arnold/aovs/denoise_albedo_noice/lpe_expression: "((C<TD>A)|(CVA)|(C<RD>A))"
arnold/aovs/denoise_albedo_noice/source: "denoise_albedo"
arnold/aovs/emission/filter: "gaussian_filter"
arnold/aovs/emission/filter_width: 2
arnold/aovs/emission/lpe: 1
arnold/aovs/emission/lpe_expression: "C[LO]"
arnold/aovs/emission/source: "emission"
arnold/aovs/motionvector/filter: "gaussian_filter"
arnold/aovs/motionvector/filter_width: 2
arnold/aovs/motionvector/source: "motionvector"
arnold/aovs/N/filter: "gaussian_filter"
arnold/aovs/N/filter_width: 2
arnold/aovs/N/source: "N"
arnold/aovs/P/filter: "gaussian_filter"
arnold/aovs/P/filter_width: 2
arnold/aovs/P/source: "P"
arnold/aovs/RGBA/filter: "gaussian_filter"
arnold/aovs/RGBA/filter_width: 2
arnold/aovs/RGBA/lpe: 1
arnold/aovs/RGBA/lpe_expression: "C.*"
arnold/aovs/RGBA/source: "RGBA"
arnold/aovs/RGBA_LIGHT_PRP_01/filter: "gaussian_filter"
arnold/aovs/RGBA_LIGHT_PRP_01/filter_width: 2
arnold/aovs/RGBA_LIGHT_PRP_01/source: "RGBA_LIGHT_PRP_01"
arnold/aovs/RGBA_LIGHT_PRP_01_variance/filter: "variance_filter"
arnold/aovs/RGBA_LIGHT_PRP_01_variance/filter_width: 2
arnold/aovs/RGBA_LIGHT_PRP_01_variance/source: "RGBA_LIGHT_PRP_01"
arnold/aovs/specular/filter: "gaussian_filter"
arnold/aovs/specular/filter_width: 2
arnold/aovs/specular/lpe: 1
arnold/aovs/specular/lpe_expression: "C<RS[^'coat''sheen']>.*"
arnold/aovs/specular/source: "specular"
arnold/aovs/specular_variance/filter: "variance_filter"
arnold/aovs/specular_variance/filter_width: 2
arnold/aovs/specular_variance/lpe: 1
arnold/aovs/specular_variance/lpe_expression: "C<RS[^'coat''sheen']>.*"
arnold/aovs/specular_variance/source: "specular"
arnold/aovs/sss/filter: "gaussian_filter"
arnold/aovs/sss/filter_width: 2
arnold/aovs/sss/lpe: 1
arnold/aovs/sss/lpe_expression: "C<TD>.*"
arnold/aovs/sss/source: "sss"
arnold/aovs/sss_variance/filter: "variance_filter"
arnold/aovs/sss_variance/filter_width: 2
arnold/aovs/sss_variance/lpe: 1
arnold/aovs/sss_variance/lpe_expression: "C<TD>.*"
arnold/aovs/sss_variance/source: "sss"
arnold/aovs/transmission/filter: "gaussian_filter"
arnold/aovs/transmission/filter_width: 2
arnold/aovs/transmission/lpe: 1
arnold/aovs/transmission/lpe_expression: "C<TS>.*"
arnold/aovs/transmission/source: "transmission"
arnold/aovs/uv/filter: "gaussian_filter"
arnold/aovs/uv/filter_width: 2
arnold/aovs/uv/source: "uv"
arnold/aovs/variance/filter: "variance_filter"
arnold/aovs/variance/filter_width: 2
arnold/aovs/variance/lpe: 1
arnold/aovs/variance/lpe_expression: "C.*"
arnold/aovs/variance/source: "RGBA"
arnold/auto_transparency_depth: 4
arnold/bounds_max_x: 1023
arnold/bounds_max_y: 575
arnold/bounds_min_x: 0
arnold/bounds_min_y: 0
arnold/camera/far_clip: 1e+06
arnold/camera/near_clip: 0.01
arnold/color_manager: "color_manager_ocio"
arnold/color_space: "ACES - ACEScg"
arnold/diffuse_depth: 1
arnold/diffuse_samples: 1
arnold/fps: 24
arnold/frame: 1650
arnold/host/hw: "1 x Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz (8 cores, 8 logical) with 64162MB"
arnold/host/name: ""
arnold/host/os: "Ubuntu 18.04.5 LTS (Bionic Beaver), Linux kernel 5.4.0-70-generic"
arnold/license_state: "valid"
arnold/specular_depth: 1
arnold/specular_samples: 1
arnold/sss_samples: 1
arnold/stats/date: "Tue Oct 5 17:26:30 2021"
arnold/stats/geo/curve_segments: 1.74172e+07
arnold/stats/geo/triangles: 1.47171e+08
arnold/stats/memory/peak: 22332.7
arnold/stats/memory/start: 75.6016
arnold/stats/rays/all/pixel: 28780
arnold/stats/rays/all/total: 1.69751e+10
arnold/stats/rays/camera/pixel: 38.3232
arnold/stats/rays/camera/total: 2.26039e+07
arnold/stats/time/render: 2442.23
arnold/stats/time/setup: 0.598896
arnold/texture_max_memory_MB: 4096
arnold/threads: 8
arnold/total_depth: 4
arnold/transmission_depth: 4
arnold/transmission_samples: 1
arnold/version: "Arnold 6.2.1.0 [359aaa66] linux clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/04/21 13:54:09"
arnold/volume_depth: 0
arnold/volume_samples: 0
CameraFilmApertureHorizontal: 1
CameraFilmApertureVertical: 0.5625
CameraFocalLength: 1.48008
CameraFov: 37.332
compression: "zip"
DateTime: "2021:10:05 17:26:30"
PixelAspectRatio: 1
screenWindowCenter: 0, 0
screenWindowWidth: 1
worldToCamera: 0.830845, 0.0286764, -0.555764, 0, 0.00524006, 0.998224, 0.0593402, 0, -0.556479, 0.0522147, -0.82922, 0, 22.6598, -2.05679, 16.2795, 1
worldToScreen: 2.45943, 0.15091, -0.555764, -0.555764, 0.0155114, 5.25315, 0.0593402, 0.0593402, -1.64726, 0.27478, -0.82922, -0.82922, 67.0765, -10.8239, 16.2695, 16.2795
oiio:ColorSpace: "Linear"
oiio:subimages: 1
interesting there is no Z, I am making my own Z aov for this rop. Does noice want to make its own?
noice output:
noice 6.2.1.0 [359aaa66] - the Arnold denoiser
Using 8 threads.
Loading images...
Loading file "/mnt/I/tmp/test.0655.exr".
Loading file "/mnt/I/tmp/test.0653.exr".
Loading file "/mnt/I/tmp/test.0654.exr".
Loading file "/mnt/I/tmp/test.0656.exr".
Loading file "/mnt/I/tmp/test.0657.exr".
Using feature AOV 'denoise_albedo'
Filters for feature and light AOVs are different: denoising works better with matching filters.
Using feature AOV 'N'
Working with 5 frames at 1024x576
Will denoise AOV "RGBA", using associated variance
Output file will be "/mnt/I/tmp/test_denoise.0655.exr"
Will denoise AOV "specular", using associated variance
Will denoise AOV "sss", using associated variance
Start denoising (patch radius 4, search radius 9, variance 0.55)
Denoising RGBA
Denoising specular
Denoising sss
Finished denoising
Saving image /mnt/I/tmp/test_denoise.0655.exr (1024 x 576 x 10)
