Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Noice filter warning
9 REPLIES 9
Message 1 of 10
576 Views, 9 Replies
I am getting
"Using feature AOV 'denoise_albedo'
    Filters for feature and light AOVs are different: denoising works better with matching filters.
Using feature AOV 'N'
Working with 5 frames at
I am also seeing this in the documentation
  • The beauty must use the same filter (gaussian_filter) as the other denoiser AOVs (N, Z, variance, and denoise_albedo), which are created by the Arnold plugin for you.
Is beauty not already gaussian? set in the sampling tab?
Or is there another place I need to set the filter?
Tags (3)
Labels (3)
9 REPLIES 9
Message 2 of 10
Stephen.Blair
What version of Arnold?
Can you post the noice command line?
And the Arnold log for the render (at least the part that shows the list of AOVs) ?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
in reply to: Stephen.Blair
log_aov.zip
htoa 5.6.1
noice -pr 4 -v 0.55 -ef 2 -l specular -l sss -i /mnt/tmp/main.0651.exr -o /mnt/tmp/main_denoise.0651.exr
Message 4 of 10
Stephen.Blair
I have to think it is this:
00:02:08  9968MB         | [aov] registered driver: "/out/rop_ar_main:exr:aov13:renderCamera_MAIN" (driver_exr)
00:02:08  9968MB         | [aov]  * "Z" of type FLOAT filtered by "/out/rop_ar_main:closest_filter:aov13" (closest_filter)
Another thing to check is the metadata in the EXR. That's what noice is actually reading.
For example:
C:\htoa\scripts\bin>oiiotool -v --info  denoiseme.0007.exr
// Stephen Blair
Message 5 of 10
Trying to understand the warning, is it saying that the filter for the feature aovs has to be the same as rgba correct?
Metadata:
arnold/aovs/denoise_albedo_noice/filter: "gaussian_filter"
arnold/aovs/denoise_albedo_noice/filter_width: 2
arnold/aovs/denoise_albedo_noice/lpe: 1
arnold/aovs/denoise_albedo_noice/lpe_expression: "((C<TD>A)|(CVA)|(C<RD>A))"
arnold/aovs/denoise_albedo_noice/source: "denoise_albedo"
arnold/aovs/RGBA/filter: "gaussian_filter"
arnold/aovs/RGBA/filter_width: 2
arnold/aovs/RGBA/lpe: 1
arnold/aovs/RGBA/lpe_expression: "C.*"
arnold/aovs/RGBA/source: "RGBA"
They are the same, is it possibly reporting this regardless? looking around at other posts on here, even ones you've posted it seems like this error pops up everytime
Message 6 of 10
Stephen.Blair
I don't see the Z metadata.
Could you post the full output of the noice command? And the full output of the oiiotool command? thanks
// Stephen Blair
Message 7 of 10
Apologies,
channel list: R, G, B, A, N.R, N.G, N.B, P.R, P.G, P.B, RGBA_LIGHT_PRP_01.R, RGBA_LIGHT_PRP_01.G, RGBA_LIGHT_PRP_01.B, RGBA_LIGHT_PRP_01_variance.R, RGBA_LIGHT_PRP_01_variance.G, RGBA_LIGHT_PRP_01_variance.B, denoise_albedo_noice.R, denoise_albedo_noice.G, denoise_albedo_noice.B, emission.R, emission.G, emission.B, motionvector.R, motionvector.G, motionvector.B, specular.R, specular.G, specular.B, specular_variance.R, specular_variance.G, specular_variance.B, sss.R, sss.G, sss.B, sss_variance.R, sss_variance.G, sss_variance.B, transmission.R, transmission.G, transmission.B, uv.R, uv.G, uv.B, variance.R, variance.G, variance.B, variance.A
    arnold/AA_samples: 3
    arnold/AA_seed: 1650
    arnold/aovs/emission/filter: "gaussian_filter"
    arnold/aovs/emission/filter_width: 2
    arnold/aovs/emission/lpe: 1
    arnold/aovs/emission/lpe_expression: "C[LO]"
    arnold/aovs/emission/source: "emission"
    arnold/aovs/motionvector/filter: "gaussian_filter"
    arnold/aovs/motionvector/filter_width: 2
    arnold/aovs/motionvector/source: "motionvector"
    arnold/aovs/N/filter: "gaussian_filter"
    arnold/aovs/N/filter_width: 2
    arnold/aovs/N/source: "N"
    arnold/aovs/P/filter: "gaussian_filter"
    arnold/aovs/P/filter_width: 2
    arnold/aovs/P/source: "P"
    arnold/aovs/RGBA_LIGHT_PRP_01/filter: "gaussian_filter"
    arnold/aovs/RGBA_LIGHT_PRP_01/filter_width: 2
    arnold/aovs/RGBA_LIGHT_PRP_01/source: "RGBA_LIGHT_PRP_01"
    arnold/aovs/RGBA_LIGHT_PRP_01_variance/filter: "variance_filter"
    arnold/aovs/RGBA_LIGHT_PRP_01_variance/filter_width: 2
    arnold/aovs/RGBA_LIGHT_PRP_01_variance/source: "RGBA_LIGHT_PRP_01"
    arnold/aovs/specular/filter: "gaussian_filter"
    arnold/aovs/specular/filter_width: 2
    arnold/aovs/specular/lpe: 1
    arnold/aovs/specular/lpe_expression: "C<RS[^'coat''sheen']>.*"
    arnold/aovs/specular/source: "specular"
    arnold/aovs/specular_variance/filter: "variance_filter"
    arnold/aovs/specular_variance/filter_width: 2
    arnold/aovs/specular_variance/lpe: 1
    arnold/aovs/specular_variance/lpe_expression: "C<RS[^'coat''sheen']>.*"
    arnold/aovs/specular_variance/source: "specular"
    arnold/aovs/sss/filter: "gaussian_filter"
    arnold/aovs/sss/filter_width: 2
    arnold/aovs/sss/lpe: 1
    arnold/aovs/sss/lpe_expression: "C<TD>.*"
    arnold/aovs/sss/source: "sss"
    arnold/aovs/sss_variance/filter: "variance_filter"
    arnold/aovs/sss_variance/filter_width: 2
    arnold/aovs/sss_variance/lpe: 1
    arnold/aovs/sss_variance/lpe_expression: "C<TD>.*"
    arnold/aovs/sss_variance/source: "sss"
    arnold/aovs/transmission/filter: "gaussian_filter"
    arnold/aovs/transmission/filter_width: 2
    arnold/aovs/transmission/lpe: 1
    arnold/aovs/transmission/lpe_expression: "C<TS>.*"
    arnold/aovs/transmission/source: "transmission"
    arnold/aovs/uv/filter: "gaussian_filter"
    arnold/aovs/uv/filter_width: 2
    arnold/aovs/uv/source: "uv"
    arnold/aovs/variance/filter: "variance_filter"
    arnold/aovs/variance/filter_width: 2
    arnold/aovs/variance/lpe: 1
    arnold/aovs/variance/lpe_expression: "C.*"
    arnold/aovs/variance/source: "RGBA"
    arnold/auto_transparency_depth: 4
    arnold/bounds_max_x: 1023
    arnold/bounds_max_y: 575
    arnold/bounds_min_x: 0
    arnold/bounds_min_y: 0
    arnold/camera/far_clip: 1e+06
    arnold/camera/near_clip: 0.01
    arnold/color_manager: "color_manager_ocio"
    arnold/color_space: "ACES - ACEScg"
    arnold/diffuse_depth: 1
    arnold/diffuse_samples: 1
    arnold/fps: 24
    arnold/frame: 1650
    arnold/host/hw: "1 x Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz (8 cores, 8 logical) with 64162MB"
    arnold/host/name: ""
    arnold/host/os: "Ubuntu 18.04.5 LTS (Bionic Beaver), Linux kernel 5.4.0-70-generic"
    arnold/license_state: "valid"
    arnold/specular_depth: 1
    arnold/specular_samples: 1
    arnold/sss_samples: 1
    arnold/stats/date: "Tue Oct  5 17:26:30 2021"
    arnold/stats/geo/curve_segments: 1.74172e+07
    arnold/stats/geo/triangles: 1.47171e+08
    arnold/stats/memory/peak: 22332.7
    arnold/stats/memory/start: 75.6016
    arnold/stats/rays/all/pixel: 28780
    arnold/stats/rays/all/total: 1.69751e+10
    arnold/stats/rays/camera/pixel: 38.3232
    arnold/stats/rays/camera/total: 2.26039e+07
    arnold/stats/time/render: 2442.23
    arnold/stats/time/setup: 0.598896
    arnold/texture_max_memory_MB: 4096
    arnold/threads: 8
    arnold/total_depth: 4
    arnold/transmission_depth: 4
    arnold/transmission_samples: 1
    arnold/version: "Arnold 6.2.1.0 [359aaa66] linux clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/04/21 13:54:09"
    arnold/volume_depth: 0
    arnold/volume_samples: 0
    CameraFilmApertureHorizontal: 1
    CameraFilmApertureVertical: 0.5625
    CameraFocalLength: 1.48008
    CameraFov: 37.332
    compression: "zip"
    DateTime: "2021:10:05 17:26:30"
    PixelAspectRatio: 1
    screenWindowCenter: 0, 0
    screenWindowWidth: 1
    worldToCamera: 0.830845, 0.0286764, -0.555764, 0, 0.00524006, 0.998224, 0.0593402, 0, -0.556479, 0.0522147, -0.82922, 0, 22.6598, -2.05679, 16.2795, 1
    worldToScreen: 2.45943, 0.15091, -0.555764, -0.555764, 0.0155114, 5.25315, 0.0593402, 0.0593402, -1.64726, 0.27478, -0.82922, -0.82922, 67.0765, -10.8239, 16.2695, 16.2795
    oiio:ColorSpace: "Linear"
    oiio:subimages: 1
interesting there is no Z, I am making my own Z aov for this rop. Does noice want to make its own?
noice output:
noice 6.2.1.0 [359aaa66] - the Arnold denoiser
Using 8 threads.
Loading images...
Loading file "/mnt/I/tmp/test.0655.exr".
Loading file "/mnt/I/tmp/test.0653.exr".
Loading file "/mnt/I/tmp/test.0654.exr".
Loading file "/mnt/I/tmp/test.0656.exr".
Loading file "/mnt/I/tmp/test.0657.exr".
Working with 5 frames at 1024x576
Will denoise AOV "RGBA", using associated variance
   Output file will be "/mnt/I/tmp/test_denoise.0655.exr"
Will denoise AOV "specular", using associated variance
Will denoise AOV "sss", using associated variance
Start denoising (patch radius 4, search radius 9, variance 0.55)
Denoising RGBA
Denoising specular
Denoising sss
Finished denoising
Saving image /mnt/I/tmp/test_denoise.0655.exr (1024 x 576 x 10)
Message 8 of 10
looking again, I forgot that I am writing Z out to a seperate exr
Message 9 of 10
Stephen.Blair
Ah, separate EXRs for everything. You're right, that may always trigger the warning (eg it's a bug). I was testing with a merged EXR,
// Stephen Blair
Message 10 of 10
Ok cool thank you for the help! One less warning to worry about 🙂
