Memory Access Violation - Crashing on Renderfarm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey everyone, I'm trying to render our university project from Houdini to Arnold using our render farm, but we keep getting a tonne of errors that say "Memory Access Violation". We have checked our scenes, and none of the warnings in the logs seem to exist at all. We only have this issue when doing one of the following.
Adding fur/groom using 'hairgen' to our lit scene. Adding lights to a scene with the 'hairgen' in. The lights are Arnold Lights.
We also get "segmentation error" as well.
We can render locally without issues, but it's too slow to render shots.
This is the render log:
======================================================= Error ======================================================= Error: Renderer returned non-zero error code, -1073741819, which represents a Memory Access Violation. There may not be enough memory, or the memory has become corrupt. at Deadline.Plugins.PluginWrapper.RenderTasks(String taskId, Int32 startFrame, Int32 endFrame, String& outMessage, AbortLevel& abortLevel) ======================================================= Type ======================================================= RenderPluginException ======================================================= Stack Trace ======================================================= at Deadline.Plugins.SandboxedPlugin.d(DeadlineMessage azg) at Deadline.Plugins.SandboxedPlugin.RenderTask(String taskId, Int32 startFrame, Int32 endFrame) at Deadline.Nodes.NodeRenderThread.c(TaskLogWriter adq) ======================================================= Log ======================================================= 2020-04-19 22:52:06: 0: Loading Job's Plugin timeout is Disabled 2020-04-19 22:52:08: 0: Executing plugin command of type 'Sync Files for Job' 2020-04-19 22:52:09: 0: Synchronization time for job files: 463.707 ms 2020-04-19 22:52:09: 0: Synchronizing Plugin Houdini from \\deadline.herts.ac.uk\DeadlineRepository10\plugins\Houdini took: 0 seconds 2020-04-19 22:52:09: 0: Done executing plugin command of type 'Sync Files for Job' 2020-04-19 22:52:09: 0: Executing plugin command of type 'Initialize Plugin' 2020-04-19 22:52:09: 0: INFO: Executing plugin script 'C:\Users\renderfarm\AppData\Local\Thinkbox\Deadline10\node\CTA-B12-REND09\plugins\5e9cc7cffdfebd3838f9f148\Houdini.py' 2020-04-19 22:52:09: 0: INFO: About: Houdini Plugin for Deadline 2020-04-19 22:52:09: 0: INFO: Render Job As User disabled, running as current user 'renderfarm' 2020-04-19 22:52:09: 0: INFO: The job's environment will be merged with the current environment before rendering 2020-04-19 22:52:09: 0: Done executing plugin command of type 'Initialize Plugin' 2020-04-19 22:52:10: 0: Start Job timeout is disabled. 2020-04-19 22:52:10: 0: Task timeout is 2700 seconds (Regular Task Timeout) 2020-04-19 22:52:10: 0: Loaded job: wb_sh1230_027 - /obj/render/spec (5e9cc7cffdfebd3838f9f148) 2020-04-19 22:52:10: 0: Executing plugin command of type 'Start Job' 2020-04-19 22:52:10: 0: DEBUG: S3BackedCache Client is not installed. 2020-04-19 22:52:10: 0: INFO: Executing global asset transfer preload script 'C:\Users\renderfarm\AppData\Local\Thinkbox\Deadline10\node\CTA-B12-REND09\plugins\5e9cc7cffdfebd3838f9f148\GlobalAssetTransferPreLoad.py' 2020-04-19 22:52:10: 0: INFO: Looking for AWS Portal File Transfer... 2020-04-19 22:52:10: 0: INFO: Looking for File Transfer controller in C:/Program Files/Thinkbox/S3BackedCache/bin/task.py... 2020-04-19 22:52:10: 0: INFO: Could not find AWS Portal File Transfer. 2020-04-19 22:52:10: 0: INFO: AWS Portal File Transfer is not installed on the system. 2020-04-19 22:52:10: 0: Done executing plugin command of type 'Start Job' 2020-04-19 22:52:10: 0: Plugin rendering frame(s): 1002 2020-04-19 22:52:10: 0: Executing plugin command of type 'Render Task' 2020-04-19 22:52:10: 0: INFO: Starting Houdini Job 2020-04-19 22:52:10: 0: INFO: Stdout Redirection Enabled: True 2020-04-19 22:52:10: 0: INFO: Stdout Handling Enabled: True 2020-04-19 22:52:10: 0: INFO: Popup Handling Enabled: True 2020-04-19 22:52:10: 0: INFO: QT Popup Handling Enabled: False 2020-04-19 22:52:10: 0: INFO: WindowsForms10.Window.8.app.* Popup Handling Enabled: False 2020-04-19 22:52:10: 0: INFO: Using Process Tree: True 2020-04-19 22:52:10: 0: INFO: Hiding DOS Window: True 2020-04-19 22:52:10: 0: INFO: Creating New Console: False 2020-04-19 22:52:10: 0: INFO: Running as user: renderfarm 2020-04-19 22:52:10: 0: INFO: Executable: "C:\Program Files\Side Effects Software\Houdini 17.5.229\bin\Hython.exe" 2020-04-19 22:52:10: 0: INFO: Argument: "C:\Users\renderfarm\AppData\Local\Thinkbox\Deadline10\node\CTA-B12-REND09\plugins\5e9cc7cffdfebd3838f9f148\hrender_dl.py" -f 1002 1002 1 -g -d /obj/render/spec "C:/Users/renderfarm/AppData/Local/Thinkbox/Deadline10/node/CTA-B12-REND09/jobsData/5e9cc7cffdfebd3838f9f148/wb_sh1230_027.hipnc" 2020-04-19 22:52:10: 0: INFO: Full Command: "C:\Program Files\Side Effects Software\Houdini 17.5.229\bin\Hython.exe" "C:\Users\renderfarm\AppData\Local\Thinkbox\Deadline10\node\CTA-B12-REND09\plugins\5e9cc7cffdfebd3838f9f148\hrender_dl.py" -f 1002 1002 1 -g -d /obj/render/spec "C:/Users/renderfarm/AppData/Local/Thinkbox/Deadline10/node/CTA-B12-REND09/jobsData/5e9cc7cffdfebd3838f9f148/wb_sh1230_027.hipnc" 2020-04-19 22:52:10: 0: INFO: Startup Directory: "C:\Program Files\Side Effects Software\Houdini 17.5.229\bin" 2020-04-19 22:52:10: 0: INFO: Process Priority: BelowNormal 2020-04-19 22:52:10: 0: INFO: Process Affinity: default 2020-04-19 22:52:10: 0: INFO: Process is now running 2020-04-19 22:52:10: 0: STDOUT: EnvControl: HOUDINI_USER_PREF_DIR missing __HVER__, ignored. 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | log started Sun Apr 19 22:52:11 2020 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | Arnold 5.3.0.2 [f7602f75] windows icc-17.0.2 oiio-2.1.0 osl-1.11.0 vdb-4.0.0 clm-1.0.3.513 rlm-12.4.2 optix-6.0.0 2019/04/09 17:16:44 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | running on CTA-B12-REND09, pid=9836 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | 2 x Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz (16 cores, 32 logical) with 65422MB 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | Windows 8 (version 6.2, build 9200) 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | soft limit for open files raised from 512 to 2048 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | [htoa_op] Begin registration ... 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | loading plugins from C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/plugins ... 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 187MB | alembic_proc.dll: alembic uses Arnold 5.3.0.2 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | cryptomatte.dll: cryptomatte uses Arnold 5.3.0.2 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | cryptomatte.dll: cryptomatte_filter uses Arnold 5.3.0.2 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 5.3.0.2 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 5.3.0.2 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | loaded 5 plugins from 3 lib(s) in 0:00.00 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [htoa_op] Loading metadata file: C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/metadata/cameras.mtd 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [htoa_op] Loading metadata file: C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/metadata/lights.mtd 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [htoa_op] Loading metadata file: C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/metadata/operators.mtd 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [htoa_op] Loading metadata file: C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/metadata/options.mtd 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [htoa_op] Loading metadata file: C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/metadata/shaders.mtd 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [htoa_op] Loading metadata file: C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold/metadata/shapes.mtd 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [rop_operators] Registering operators ... 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 188MB | [rop_operators] operator registration done. 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 204MB | [vop_shaders] Registering shaders ... 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 206MB | [vop_shaders] shader registration done. 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 206MB | [htoa_op] End registration. 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 206MB | 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 206MB | releasing resources 2020-04-19 22:52:12: 0: STDOUT: 00:00:00 205MB | Arnold shutdown 2020-04-19 22:52:14: 0: STDOUT: Detected Houdini version: (17, 5, 229) 2020-04-19 22:52:14: 0: STDOUT: ['C:\\Users\\renderfarm\\AppData\\Local\\Thinkbox\\Deadline10\\node\\CTA-B12-REND09\\plugins\\5e9cc7cffdfebd3838f9f148\\hrender_dl.py', '-f', '1002', '1002', '1', '-g', '-d', '/obj/render/spec', 'C:/Users/renderfarm/AppData/Local/Thinkbox/Deadline10/node/CTA-B12-REND09/jobsData/5e9cc7cffdfebd3838f9f148/wb_sh1230_027.hipnc'] 2020-04-19 22:52:14: 0: STDOUT: Start: 1002 2020-04-19 22:52:14: 0: STDOUT: End: 1002 2020-04-19 22:52:14: 0: STDOUT: Increment: 1 2020-04-19 22:52:14: 0: STDOUT: Ignore Inputs: True 2020-04-19 22:52:14: 0: STDOUT: No output specified. Output will be handled by the driver 2020-04-19 22:52:14: 0: STDOUT: Driver: /obj/render/spec 2020-04-19 22:52:14: 0: STDOUT: Input File: C:/Users/renderfarm/AppData/Local/Thinkbox/Deadline10/node/CTA-B12-REND09/jobsData/5e9cc7cffdfebd3838f9f148/wb_sh1230_027.hipnc 2020-04-19 22:52:34: 0: STDOUT: Warnings were generated during load. 2020-04-19 22:52:34: 0: STDOUT: Error loading: C:/Users/renderfarm/AppData/Local/Thinkbox/Deadline10/node/CTA-B12-REND09/jobsData/5e9cc7cffdfebd3838f9f148/wb_sh1230_027.hipnc 2020-04-19 22:52:34: 0: STDOUT: Warning: 2020-04-19 22:52:34: 0: STDOUT: /obj/assetShaders/guardHairs/red_Hairs: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/assetShaders/guardHairs/light_Hairs: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/assetShaders/Cornea/ramp_float1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "use_implicit_uvs". 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/materials/guardHairs/red_Hairs: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/materials/guardHairs/light_Hairs: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/materials/Cornea/ramp_float1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "use_implicit_uvs". 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/rim/shopnet/arnold_vopnet/ramp_rgb1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/blue_fill/shopnet/arnold_vopnet/ramp_rgb1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/orange_fill/shopnet/arnold_vopnet/ramp_rgb1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/bounce/shopnet/arnold_vopnet/ramp_rgb1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/face_rim/shopnet/arnold_vopnet/ramp_rgb1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "wrap_uvs". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/spec: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/shadow: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/scatter: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/reflection: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/utility: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/cryptomatte: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/deadline1: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "dl_limit_frames_to_node". 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "dl_frame_dependent". 2020-04-19 22:52:34: 0: STDOUT: 2020-04-19 22:52:34: 0: STDOUT: /obj/render/lookdev: 2020-04-19 22:52:34: 0: STDOUT: Skipping unrecognized parameter "ar_export_referenced_materials". 2020-04-19 22:52:34: 0: STDOUT: ROP type: arnold 2020-04-19 22:52:34: 0: STDOUT: Enabled log to console 2020-04-19 22:52:34: 0: STDOUT: Set verbosity to detailed 2020-04-19 22:52:34: 0: STDOUT: Rendering frame 1002 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | log started Sun Apr 19 22:52:34 2020 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | Arnold 5.3.0.2 [f7602f75] windows icc-17.0.2 oiio-2.1.0 osl-1.11.0 vdb-4.0.0 clm-1.0.3.513 rlm-12.4.2 optix-6.0.0 2019/04/09 17:16:44 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | running on CTA-B12-REND09, pid=9836 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | 2 x Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz (16 cores, 32 logical) with 65422MB 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | Windows 8 (version 6.2, build 9200) 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | soft limit for open files raised from 2048 to 2048 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | loading plugins from C:/Docs/houdini17.5/plugins/HtoA/htoa-4.0.2_r236e192_houdini-17.5.229/arnold\plugins ... 2020-04-19 22:52:34: 0: STDOUT: 00:00:00 1038MB | loaded 5 plugins from 3 lib(s) in 0:00.00 2020-04-19 22:52:35: 0: STDOUT: 00:00:00 1127MB WARNING | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type) 2020-04-19 22:56:11: 0: STDOUT: 00:03:36 13151MB ERROR | signal caught: error C0000005 -- access violation 2020-04-19 22:56:11: 0: STDOUT: **** 2020-04-19 22:56:11: 0: STDOUT: * Arnold 5.3.0.2 [f7602f75] windows icc-17.0.2 oiio-2.1.0 osl-1.11.0 vdb-4.0.0 clm-1.0.3.513 rlm-12.4.2 optix-6.0.0 2019/04/09 17:16:44 2020-04-19 22:56:11: 0: STDOUT: * CRASHED in tbbmalloc (0x000000001180acab) at 00:00:00, pixel (0, 0) 2020-04-19 22:56:11: 0: STDOUT: * signal caught: error C0000005 -- access violation 2020-04-19 22:56:11: 0: STDOUT: * 2020-04-19 22:56:11: 0: STDOUT: * backtrace: 2020-04-19 22:56:11: 0: STDOUT: * 0 0x00007ffe37f0bf4e [ai ] 2020-04-19 22:56:11: 0: STDOUT: * 1 0x00007ffe37f0b1ef [ai ] 2020-04-19 22:56:11: 0: STDOUT: * 2 0x00007ffe893f53ac [KERNELBASE] UnhandledExceptionFilter 2020-04-19 22:56:11: 0: STDOUT: * 3 0x00007ffe8c937100 [ntdll ] memset 2020-04-19 22:56:11: 0: STDOUT: * 4 0x00007ffe8c91f306 [ntdll ] _C_specific_handler 2020-04-19 22:56:11: 0: STDOUT: * 5 0x00007ffe8c9335af [ntdll ] _chkstk 2020-04-19 22:56:11: 0: STDOUT: * 6 0x00007ffe8c894aaf [ntdll ] RtlWalkFrameChain 2020-04-19 22:56:11: 0: STDOUT: * 7 0x00007ffe8c93231e [ntdll ] KiUserExceptionDispatcher 2020-04-19 22:56:11: 0: STDOUT: >> 8 0x000000001180acab [tbbmalloc ] 2020-04-19 22:56:11: 0: STDOUT: * 9 0x000000001180c993 [tbbmalloc ] 2020-04-19 22:56:11: 0: STDOUT: * 10 0x000000001180d3fb [tbbmalloc ] scalable_malloc 2020-04-19 22:56:11: 0: STDOUT: * 11 0x000000002033d119 [libGU ] GU_CleanTools::gu_EdgeMap::entries 2020-04-19 22:56:11: 0: STDOUT: * 12 0x00000000208ebb8d [libGU ] GU_PrimPoly::removeEdges 2020-04-19 22:56:11: 0: STDOUT: * 13 0x00000000208ece6d [libGU ] GU_PrimPoly::removeEdges 2020-04-19 22:56:11: 0: STDOUT: * 14 0x00000000208efdd2 [libGU ] GU_PrimPolySoup::countMemory 2020-04-19 22:56:11: 0: STDOUT: * 15 0x0000000024adf236 [tbb ] tbb::interface7::internal::task_arena_base::internal_max_concurrency 2020-04-19 22:56:11: 0: STDOUT: * 16 0x0000000024ad90c0 [tbb ] tbb::task_scheduler_init::default_num_threads 2020-04-19 22:56:11: 0: STDOUT: * 17 0x0000000024ad8656 [tbb ] tbb::task_scheduler_init::default_num_threads 2020-04-19 22:56:11: 0: STDOUT: * 18 0x0000000024ad393c [tbb ] tbb::internal::thread_sleep_v3 2020-04-19 22:56:11: 0: STDOUT: * 19 0x0000000024ad38bb [tbb ] tbb::internal::thread_sleep_v3 2020-04-19 22:56:11: 0: STDOUT: * 20 0x00007ffe899403ba [ucrtbase ] o_exp 2020-04-19 22:56:11: 0: STDOUT: * 21 0x00007ffe8bee7e94 [KERNEL32 ] BaseThreadInitThunk 2020-04-19 22:56:11: 0: STDOUT: * 22 0x00007ffe8c8f7ad1 [ntdll ] RtlUserThreadStart 2020-04-19 22:56:11: 0: STDOUT: * 2020-04-19 22:56:11: 0: STDOUT: * loaded modules: 2020-04-19 22:56:11: 0: STDOUT: * 0x00007ffe37bf0000 ai 2020-04-19 22:56:11: 0: STDOUT: * 0x00007ffe89370000 KERNELBASE 2020-04-19 22:56:11: 0: STDOUT: * 0x00007ffe8c890000 ntdll 2020-04-19 22:56:11: 0: STDOUT: * 0x0000000011800000 tbbmalloc 2020-04-19 22:56:11: 0: STDOUT: * 0x000000001aa30000 libGU 2020-04-19 22:56:11: 0: STDOUT: * 0x0000000024ac0000 tbb 2020-04-19 22:56:11: 0: STDOUT: * 0x00007ffe89920000 ucrtbase 2020-04-19 22:56:11: 0: STDOUT: * 0x00007ffe8bed0000 KERNEL32 2020-04-19 22:56:11: 0: STDOUT: **** 2020-04-19 22:56:16: 0: INFO: Process exit code: -1073741819 2020-04-19 22:56:16: 0: Done executing plugin command of type 'Render Task' ======================================================= Details ======================================================= Date: 04/19/2020 22:56:17 Frames: 1002 Elapsed Time: 00:00:04:11 Job Submit Date: 04/19/2020 22:51:11 Job User: XXXXXXXXXXX Average RAM Usage: 13356046336 (20%) Peak RAM Usage: 20436717568 (30%) Average CPU Usage: 30% Peak CPU Usage: 100% Used CPU Clocks (x10^6 cycles): 4976449 Total CPU Clocks (x10^6 cycles): 16588161 ======================================================= Node Information ======================================================= Node Name: XXXXXXXXXXX Version: v10.0.28.2 Release (31a4a2e50) Operating System: Windows 10 Education Running As Service: No Machine User: renderfarm IP Address: XXXXXXXXXXX MAC Address: XXXXXXXXXXX CPU Architecture: x64 CPUs: 32 CPU Usage: 5% Memory Usage: 17.5 GB / 63.9 GB (27%) Free Disk Space: 51.436 GB Video Card: ASPEED Graphics Family(WDDM)
