Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Light Blocker - HtoA
13 REPLIES 13
Message 1 of 14
Andrew_Wilkins1
2017 Views, 13 Replies
Good day,
Regarding the "Light Blocker" in HtoA
https://docs.arnoldrenderer.com/display/A5AFHUG/Light+Blocker
This node is supported in HtoA but is an initial implementation and is not very user friendly. It lacks the viewport preview to move and control the blocker shape.
Very much agreed!
Any ideas when the view port manipulator would be implemented?
This feature sees heavy use and atm unusable out of the box compared to Maya.
Found a post from 2018, with a work-around that would be tedious to manage on an actual production:
https://answers.arnoldrenderer.com/questions/8618/houdini-165-arnold-light-blocker.html
A bit worrisome we're in 2021 but this hasn't been implemented yet.
All the best,
Andrew
Tags (2)
Labels (2)
13 REPLIES 13
Message 2 of 14
There's no ETA
I see there is this:
https://bhavesh7393.gumroad.com/l/halbt?fbclid=IwAR20kXmq3-Q-2vVnuBkXC9nJMLXbQE85O9jfgqgCReyipwN-hEF...
// Stephen Blair
// Arnold Renderer Support
Message 3 of 14
Hey there,
Thanks!
This should actually help a lot. Let me try it out.
I was already starting to code something myself. 🙂
Message 4 of 14
Also, I added your name to the list of customers asking for this feature...the bigger the list the better (for getting the feature done 😉
// Stephen Blair
Message 5 of 14
Alright sounds good! :hot_beverage:
Somehow these light blockers become bread & butter for artists, I've easily seen between 15-30+ in shot.
This script works great btw, thanks again for finding it.
needs some adjustments though, doesn't seem to handle creating multiple light blockers for the same light etc.
Message 6 of 14
in reply to: Andrew_Wilkins1
i may be too late, its a good idea, ill update my script to attach single light blocker to all selected lights, thanks for the suggestion, right now script is creating blocker per light.
Message 7 of 14
am_wilkins
Hey Bhavesh,
Thanks so much for the script!
Np, yeah it's just a good idea to re-use as many blockers as possible. Keeps the scene / light setup a bit more manageable. 🙂
Message 8 of 14
I have worked on a tool to attach Light Blocker to multiple lights, which works with all Light Filters.
https://bhavesh7393.artstation.com/pages/houdini-arnold-light-filter-manager
Message 9 of 14
aman4
Is there any way to link more than one light blocker to a single light ? @Anonymous
Currently as per the HDA, I can only link one per light, that is why I am asking.
Message 10 of 14
there's something similar in solaris? Or there's a way to move easily a gizmo with geometry matrix?
thanks
Message 11 of 14
I actually haven't re-created this tool/code to create these more artist friendly light-blockers for Solaris.
Although might be on my list to do in the near future.
TBH, might be worth just using geo cards instead.
I do wish the Arnold team would make their features actually usable by artists without any extra dev or setup work.
best,
amwilkins
Message 12 of 14
Hi andrew,
what do you mean by geo cards? plans that block the light?
Message 13 of 14
Yeah exactly, geometry planes that don't contribute to the scene only casting shadows.
Can add ramp material to them to adjust opacity falloffs if needed and also do light-linking so they only impact certain lights.
amwilkins
Message 14 of 14
thakyou for your support
