Hello, we're having big watermaks problems with arnold on houdini (Houdini 17.5.327, HtoA 4.2.0, Arnold 5.4.0.0) on our render farm at school. It's getting more and more worrying since around 20% of our rendered images have watermarks now. When rendering locally, we don't have any problems, no watermark at all. Reading our render logs, and searching for old posts and the doc, we often found that the problem comes from the ADSKFLEX_LICENSE_FILE, here's the part of our render log when arnold can't find the license (@multifct is the server where our license is installed) :
00:00:03 1369MB | authorizing with default license managers: rlm, clm ... 00:00:04 1374MB WARNING | rendering with watermarks because of failed authorization: 00:00:04 1374MB | [rlm] error initializing license system: 00:00:04 1374MB | [rlm] * Can't read license data (-102) 00:00:04 1374MB | [clm.v1] generic license checkout error (22) 00:00:04 1374MB | environment variables: 00:00:04 1374MB | ARNOLD_LICENSE_MANAGER = (not set) 00:00:04 1374MB | [rlm] solidangle_LICENSE = (not set) 00:00:04 1374MB | [rlm] RLM_LICENSE = (not set) 00:00:04 1374MB | [clm] ADSKFLEX_LICENSE_FILE = @multifct 00:00:04 1374MB | [clm] LM_LICENSE_FILE = (not set)
That being said, the server where we have all our files, scenes, etc. (not @multifct) is getting really busy/slow because everyone is launching renders, maybe it's the cause ? And apparently, last year, students didn't have as much watermark problems as we have. We'd like to know if there is a solution to definitely solve this watermark issue, this is getting pretty annoying because now we are spending more time finding and render them back, rather to actually work on our project
So we're using the port 5053, it is working because we wouldn't be able to load the engine if the ports settings were wrong. And it's neither a license number problem, we have 3000 of them at school
We tried constantly pinging between @multifct and our files server(@marvin), the ping was around 10-15 ms and we still had watermarks.
Using the Command Line Tool, this is an example of the scripts Tractor dispatch to multiple computers :
%D(C:/Houdini17/bin/hython.exe) %D(//marvin/PFE_RN_2020/_UTILITY/04_FARM/01_HOUDINI/hrender_artfx.py) %D(I:/SynologyDrive/RESURGENCE/03_WORK_PIPE/02_SHOT/3d/scenes/s050/p070/render/main/render/work_v004_s050_p070_06-19-2020_19-01-11.hipnc) -d /out/ROP_FARM_Fx_Bulles -F 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 i7-mk6-2016-14
We also checked the Adlm files located in %LOCALAPPDATA%\Autodesk\Logs\Adlm.log on a few computers, they look like this, it's strange because when reading the lines dates, there were no updates since March :
8424 2019/10/03 09:58:35 Reason=Fatal error
8424 2019/10/03 09:58:35 ComputerName=x1-mk10-2019-01
8424 2019/10/03 09:58:35 OS=6.2.9200.
8424 2019/10/03 09:58:35 File=AdlmIntLicenseMgr.cpp,Line=1530
8424 2019/10/03 09:58:35 VendorID=6
8424 2019/10/03 09:58:35 VendorError=2
8424 2019/10/03 09:58:35 File=AdlmIntLicenseMgr.cpp,Line=1532
8424 2019/10/03 09:58:35 AdlmIntError=1
10272 2019/11/25 13:11:50 Reason=Fatal error
10272 2019/11/25 13:11:50 ComputerName=i7-mk5-2015-32
10272 2019/11/25 13:11:50 OS=6.2.9200.
10272 2019/11/25 13:11:50 File=AdlmIntLicenseMgr.cpp,Line=1530
10272 2019/11/25 13:11:50 VendorID=6
10272 2019/11/25 13:11:50 VendorError=2
10272 2019/11/25 13:11:50 File=AdlmIntLicenseMgr.cpp,Line=1532
10272 2019/11/25 13:11:50 AdlmIntError=1
11156 2019/11/26 13:08:59 Reason=Fatal error
11156 2019/11/26 13:08:59 ComputerName=i7-mk5-2015-32
11156 2019/11/26 13:08:59 OS=6.2.9200.
11156 2019/11/26 13:08:59 File=AdlmIntLicenseMgr.cpp,Line=1530
11156 2019/11/26 13:08:59 VendorID=6
11156 2019/11/26 13:08:59 VendorError=2
11156 2019/11/26 13:08:59 File=AdlmIntLicenseMgr.cpp,Line=1532
11156 2019/11/26 13:08:59 AdlmIntError=1
9408 2019/11/26 13:25:53 Reason=Fatal error
9408 2019/11/26 13:25:53 ComputerName=i7-mk5-2015-32
9408 2019/11/26 13:25:53 OS=6.2.9200.
9408 2019/11/26 13:25:53 File=AdlmIntLicenseMgr.cpp,Line=1530
9408 2019/11/26 13:25:53 VendorID=6
9408 2019/11/26 13:25:53 VendorError=2
9408 2019/11/26 13:25:53 File=AdlmIntLicenseMgr.cpp,Line=1532
9408 2019/11/26 13:25:53 AdlmIntError=1
11216 2019/11/26 13:27:33 Reason=Fatal error
11216 2019/11/26 13:27:33 ComputerName=i7-mk5-2015-32
11216 2019/11/26 13:27:33 OS=6.2.9200.
11216 2019/11/26 13:27:33 File=AdlmIntLicenseMgr.cpp,Line=1530
11216 2019/11/26 13:27:33 VendorID=6
11216 2019/11/26 13:27:33 VendorError=2
11216 2019/11/26 13:27:33 File=AdlmIntLicenseMgr.cpp,Line=1532
11216 2019/11/26 13:27:33 AdlmIntError=1
2020 2020/02/03 08:37:22 Reason=Fatal error
2020 2020/02/03 08:37:22 ComputerName=i7-mk5-2015-32
2020 2020/02/03 08:37:22 OS=6.2.9200.
2020 2020/02/03 08:37:22 File=AdlmIntLicenseMgr.cpp,Line=1530
2020 2020/02/03 08:37:22 VendorID=6
2020 2020/02/03 08:37:22 VendorError=2
2020 2020/02/03 08:37:22 File=AdlmIntLicenseMgr.cpp,Line=1532
2020 2020/02/03 08:37:22 AdlmIntError=1
14104 2020/02/04 08:19:25 Reason=Fatal error
14104 2020/02/04 08:19:25 ComputerName=i7-mk5-2015-32
14104 2020/02/04 08:19:25 OS=6.2.9200.
14104 2020/02/04 08:19:25 File=AdlmIntLicenseMgr.cpp,Line=1530
14104 2020/02/04 08:19:25 VendorID=6
14104 2020/02/04 08:19:25 VendorError=2
14104 2020/02/04 08:19:25 File=AdlmIntLicenseMgr.cpp,Line=1532
14104 2020/02/04 08:19:25 AdlmIntError=1
8200 2020/02/04 08:20:41 Reason=Fatal error
8200 2020/02/04 08:20:41 ComputerName=i7-mk5-2015-32
8200 2020/02/04 08:20:41 OS=6.2.9200.
8200 2020/02/04 08:20:41 File=AdlmIntLicenseMgr.cpp,Line=1530
8200 2020/02/04 08:20:41 VendorID=6
8200 2020/02/04 08:20:41 VendorError=2
8200 2020/02/04 08:20:41 File=AdlmIntLicenseMgr.cpp,Line=1532
8200 2020/02/04 08:20:41 AdlmIntError=1
6540 2020/02/04 08:33:16 Reason=Fatal error
6540 2020/02/04 08:33:16 ComputerName=i7-mk5-2015-32
6540 2020/02/04 08:33:16 OS=6.2.9200.
6540 2020/02/04 08:33:16 File=AdlmIntLicenseMgr.cpp,Line=1530
6540 2020/02/04 08:33:16 VendorID=6
6540 2020/02/04 08:33:16 VendorError=2
6540 2020/02/04 08:33:16 File=AdlmIntLicenseMgr.cpp,Line=1532
6540 2020/02/04 08:33:16 AdlmIntError=1
10552 2020/02/05 08:39:28 Reason=Fatal error
10552 2020/02/05 08:39:28 ComputerName=i7-mk5-2015-32
10552 2020/02/05 08:39:28 OS=6.2.9200.
10552 2020/02/05 08:39:28 File=AdlmIntLicenseMgr.cpp,Line=1530
10552 2020/02/05 08:39:28 VendorID=6
10552 2020/02/05 08:39:28 VendorError=2
10552 2020/02/05 08:39:28 File=AdlmIntLicenseMgr.cpp,Line=1532
10552 2020/02/05 08:39:28 AdlmIntError=1
11888 2020/02/05 11:04:42 Reason=Fatal error
11888 2020/02/05 11:04:42 ComputerName=i7-mk5-2015-32
11888 2020/02/05 11:04:42 OS=6.2.9200.
11888 2020/02/05 11:04:42 File=AdlmIntLicenseMgr.cpp,Line=1530
11888 2020/02/05 11:04:42 VendorID=6
11888 2020/02/05 11:04:42 VendorError=2
11888 2020/02/05 11:04:42 File=AdlmIntLicenseMgr.cpp,Line=1532
11888 2020/02/05 11:04:42 AdlmIntError=1
7412 2020/02/06 08:55:22 Reason=Fatal error
7412 2020/02/06 08:55:22 ComputerName=i7-mk5-2015-32
7412 2020/02/06 08:55:22 OS=6.2.9200.
7412 2020/02/06 08:55:22 File=AdlmIntLicenseMgr.cpp,Line=1530
7412 2020/02/06 08:55:22 VendorID=6
7412 2020/02/06 08:55:22 VendorError=2
7412 2020/02/06 08:55:22 File=AdlmIntLicenseMgr.cpp,Line=1532
7412 2020/02/06 08:55:22 AdlmIntError=1
9372 2020/02/07 08:23:49 Reason=Fatal error
9372 2020/02/07 08:23:49 ComputerName=i7-mk5-2015-32
9372 2020/02/07 08:23:49 OS=6.2.9200.
9372 2020/02/07 08:23:49 File=AdlmIntLicenseMgr.cpp,Line=1530
9372 2020/02/07 08:23:49 VendorID=6
9372 2020/02/07 08:23:49 VendorError=2
9372 2020/02/07 08:23:49 File=AdlmIntLicenseMgr.cpp,Line=1532
9372 2020/02/07 08:23:49 AdlmIntError=1
5276 2020/02/07 09:50:21 Reason=Fatal error
5276 2020/02/07 09:50:21 ComputerName=i7-mk5-2015-32
5276 2020/02/07 09:50:21 OS=6.2.9200.
5276 2020/02/07 09:50:21 File=AdlmIntLicenseMgr.cpp,Line=1530
5276 2020/02/07 09:50:21 VendorID=6
5276 2020/02/07 09:50:21 VendorError=2
5276 2020/02/07 09:50:21 File=AdlmIntLicenseMgr.cpp,Line=1532
5276 2020/02/07 09:50:21 AdlmIntError=1
1324 2020/03/03 08:12:47 Reason=Fatal error
1324 2020/03/03 08:12:47 ComputerName=i7-mk5-2015-32
1324 2020/03/03 08:12:47 OS=6.2.9200.
1324 2020/03/03 08:12:47 File=AdlmIntLicenseMgr.cpp,Line=1530
1324 2020/03/03 08:12:47 VendorID=6
1324 2020/03/03 08:12:47 VendorError=2
1324 2020/03/03 08:12:47 File=AdlmIntLicenseMgr.cpp,Line=1532
1324 2020/03/03 08:12:47 AdlmIntError=1
7780 2020/03/03 08:18:30 Reason=Fatal error
7780 2020/03/03 08:18:30 ComputerName=i7-mk5-2015-32
7780 2020/03/03 08:18:30 OS=6.2.9200.
7780 2020/03/03 08:18:30 File=AdlmIntLicenseMgr.cpp,Line=1530
7780 2020/03/03 08:18:30 VendorID=6
7780 2020/03/03 08:18:30 VendorError=2
7780 2020/03/03 08:18:30 File=AdlmIntLicenseMgr.cpp,Line=1532
7780 2020/03/03 08:18:30 AdlmIntError=1
7312 2020/03/03 08:21:24 Reason=Fatal error
7312 2020/03/03 08:21:24 ComputerName=i7-mk5-2015-32
7312 2020/03/03 08:21:24 OS=6.2.9200.
7312 2020/03/03 08:21:24 File=AdlmIntLicenseMgr.cpp,Line=1530
7312 2020/03/03 08:21:24 VendorID=6
7312 2020/03/03 08:21:24 VendorError=2
7312 2020/03/03 08:21:24 File=AdlmIntLicenseMgr.cpp,Line=1532
7312 2020/03/03 08:21:24 AdlmIntError=1
12844 2020/03/03 08:22:18 Reason=Fatal error
12844 2020/03/03 08:22:18 ComputerName=i7-mk5-2015-32
12844 2020/03/03 08:22:18 OS=6.2.9200.
12844 2020/03/03 08:22:18 File=AdlmIntLicenseMgr.cpp,Line=1530
12844 2020/03/03 08:22:18 VendorID=6
12844 2020/03/03 08:22:18 VendorError=2
12844 2020/03/03 08:22:18 File=AdlmIntLicenseMgr.cpp,Line=1532
12844 2020/03/03 08:22:18 AdlmIntError=1
5420 2020/03/03 08:24:32 Reason=Fatal error
5420 2020/03/03 08:24:32 ComputerName=i7-mk5-2015-32
5420 2020/03/03 08:24:32 OS=6.2.9200.
5420 2020/03/03 08:24:32 File=AdlmIntLicenseMgr.cpp,Line=1530
5420 2020/03/03 08:24:32 VendorID=6
5420 2020/03/03 08:24:32 VendorError=2
5420 2020/03/03 08:24:32 File=AdlmIntLicenseMgr.cpp,Line=1532
5420 2020/03/03 08:24:32 AdlmIntError=1
15332 2020/03/03 08:25:48 Reason=Fatal error
15332 2020/03/03 08:25:48 ComputerName=i7-mk5-2015-32
15332 2020/03/03 08:25:48 OS=6.2.9200.
15332 2020/03/03 08:25:48 File=AdlmIntLicenseMgr.cpp,Line=1530
15332 2020/03/03 08:25:48 VendorID=6
15332 2020/03/03 08:25:48 VendorError=2
15332 2020/03/03 08:25:48 File=AdlmIntLicenseMgr.cpp,Line=1532
15332 2020/03/03 08:25:48 AdlmIntError=1
12400 2020/03/03 08:26:58 Reason=Fatal error
12400 2020/03/03 08:26:58 ComputerName=i7-mk5-2015-32
12400 2020/03/03 08:26:58 OS=6.2.9200.
12400 2020/03/03 08:26:58 File=AdlmIntLicenseMgr.cpp,Line=1530
12400 2020/03/03 08:26:58 VendorID=6
12400 2020/03/03 08:26:58 VendorError=2
12400 2020/03/03 08:26:58 File=AdlmIntLicenseMgr.cpp,Line=1532
12400 2020/03/03 08:26:58 AdlmIntError=1
1636 2020/03/03 08:27:44 Reason=Fatal error
1636 2020/03/03 08:27:44 ComputerName=i7-mk5-2015-32
1636 2020/03/03 08:27:44 OS=6.2.9200.
1636 2020/03/03 08:27:44 File=AdlmIntLicenseMgr.cpp,Line=1530
1636 2020/03/03 08:27:44 VendorID=6
1636 2020/03/03 08:27:44 VendorError=2
1636 2020/03/03 08:27:44 File=AdlmIntLicenseMgr.cpp,Line=1532
1636 2020/03/03 08:27:44 AdlmIntError=1
10960 2020/03/03 10:11:27 Reason=Fatal error
10960 2020/03/03 10:11:27 ComputerName=i7-mk5-2015-32
10960 2020/03/03 10:11:27 OS=6.2.9200.
10960 2020/03/03 10:11:27 File=AdlmIntLicenseMgr.cpp,Line=1530
10960 2020/03/03 10:11:27 VendorID=6
10960 2020/03/03 10:11:27 VendorError=2
10960 2020/03/03 10:11:27 File=AdlmIntLicenseMgr.cpp,Line=1532
10960 2020/03/03 10:11:27 AdlmIntError=1
12028 2020/03/03 10:15:49 Reason=Fatal error
12028 2020/03/03 10:15:49 ComputerName=i7-mk5-2015-32
12028 2020/03/03 10:15:49 OS=6.2.9200.
12028 2020/03/03 10:15:49 File=AdlmIntLicenseMgr.cpp,Line=1530
12028 2020/03/03 10:15:49 VendorID=6
12028 2020/03/03 10:15:49 VendorError=2
12028 2020/03/03 10:15:49 File=AdlmIntLicenseMgr.cpp,Line=1532
12028 2020/03/03 10:15:49 AdlmIntError=1
12944 2020/03/03 10:17:12 Reason=Fatal error
12944 2020/03/03 10:17:12 ComputerName=i7-mk5-2015-32
12944 2020/03/03 10:17:12 OS=6.2.9200.
12944 2020/03/03 10:17:12 File=AdlmIntLicenseMgr.cpp,Line=1530
12944 2020/03/03 10:17:12 VendorID=6
12944 2020/03/03 10:17:12 VendorError=2
12944 2020/03/03 10:17:12 File=AdlmIntLicenseMgr.cpp,Line=1532
12944 2020/03/03 10:17:12 AdlmIntError=1
7064 2020/03/03 10:17:38 Reason=Fatal error
7064 2020/03/03 10:17:38 ComputerName=i7-mk5-2015-32
7064 2020/03/03 10:17:38 OS=6.2.9200.
7064 2020/03/03 10:17:38 File=AdlmIntLicenseMgr.cpp,Line=1530
7064 2020/03/03 10:17:38 VendorID=6
7064 2020/03/03 10:17:38 VendorError=2
7064 2020/03/03 10:17:38 File=AdlmIntLicenseMgr.cpp,Line=1532
7064 2020/03/03 10:17:38 AdlmIntError=1
15332 2020/03/03 10:23:37 Reason=Fatal error
15332 2020/03/03 10:23:37 ComputerName=i7-mk5-2015-32
15332 2020/03/03 10:23:37 OS=6.2.9200.
15332 2020/03/03 10:23:37 File=AdlmIntLicenseMgr.cpp,Line=1530
15332 2020/03/03 10:23:37 VendorID=6
15332 2020/03/03 10:23:37 VendorError=2
15332 2020/03/03 10:23:37 File=AdlmIntLicenseMgr.cpp,Line=1532
15332 2020/03/03 10:23:37 AdlmIntError=1
8124 2020/03/03 10:24:12 Reason=Fatal error
8124 2020/03/03 10:24:12 ComputerName=i7-mk5-2015-32
8124 2020/03/03 10:24:12 OS=6.2.9200.
8124 2020/03/03 10:24:12 File=AdlmIntLicenseMgr.cpp,Line=1530
8124 2020/03/03 10:24:12 VendorID=6
8124 2020/03/03 10:24:12 VendorError=2
8124 2020/03/03 10:24:12 File=AdlmIntLicenseMgr.cpp,Line=1532
8124 2020/03/03 10:24:12 AdlmIntError=1
3004 2020/03/03 10:24:27 Reason=Fatal error
3004 2020/03/03 10:24:27 ComputerName=i7-mk5-2015-32
3004 2020/03/03 10:24:27 OS=6.2.9200.
3004 2020/03/03 10:24:27 File=AdlmIntLicenseMgr.cpp,Line=1530
3004 2020/03/03 10:24:27 VendorID=6
3004 2020/03/03 10:24:27 VendorError=2
3004 2020/03/03 10:24:27 File=AdlmIntLicenseMgr.cpp,Line=1532
3004 2020/03/03 10:24:27 AdlmIntError=1
7664 2020/03/03 11:04:53 Reason=Fatal error
7664 2020/03/03 11:04:53 ComputerName=i7-mk5-2015-32
7664 2020/03/03 11:04:53 OS=6.2.9200.
7664 2020/03/03 11:04:53 File=AdlmIntLicenseMgr.cpp,Line=1530
7664 2020/03/03 11:04:53 VendorID=6
7664 2020/03/03 11:04:53 VendorError=2
7664 2020/03/03 11:04:53 File=AdlmIntLicenseMgr.cpp,Line=1532
7664 2020/03/03 11:04:53 AdlmIntError=1
16244 2020/03/03 11:05:01 Reason=Fatal error
16244 2020/03/03 11:05:01 ComputerName=i7-mk5-2015-32
16244 2020/03/03 11:05:01 OS=6.2.9200.
16244 2020/03/03 11:05:01 File=AdlmIntLicenseMgr.cpp,Line=1530
16244 2020/03/03 11:05:01 VendorID=6
16244 2020/03/03 11:05:01 VendorError=2
16244 2020/03/03 11:05:01 File=AdlmIntLicenseMgr.cpp,Line=1532
16244 2020/03/03 11:05:01 AdlmIntError=1
14816 2020/03/03 11:06:55 Reason=Fatal error
14816 2020/03/03 11:06:55 ComputerName=i7-mk5-2015-32
14816 2020/03/03 11:06:55 OS=6.2.9200.
14816 2020/03/03 11:06:55 File=AdlmIntLicenseMgr.cpp,Line=1530
14816 2020/03/03 11:06:55 VendorID=6
14816 2020/03/03 11:06:55 VendorError=2
14816 2020/03/03 11:06:55 File=AdlmIntLicenseMgr.cpp,Line=1532
14816 2020/03/03 11:06:55 AdlmIntError=1
7664 2020/03/03 11:35:27 Reason=Fatal error
7664 2020/03/03 11:35:27 ComputerName=i7-mk5-2015-32
7664 2020/03/03 11:35:27 OS=6.2.9200.
7664 2020/03/03 11:35:27 File=AdlmIntLicenseMgr.cpp,Line=1530
7664 2020/03/03 11:35:27 VendorID=6
7664 2020/03/03 11:35:27 VendorError=2
7664 2020/03/03 11:35:27 File=AdlmIntLicenseMgr.cpp,Line=1532
7664 2020/03/03 11:35:27 AdlmIntError=1
1884 2020/03/03 11:37:32 Reason=Fatal error
1884 2020/03/03 11:37:32 ComputerName=i7-mk5-2015-32
1884 2020/03/03 11:37:32 OS=6.2.9200.
1884 2020/03/03 11:37:32 File=AdlmIntLicenseMgr.cpp,Line=1530
1884 2020/03/03 11:37:32 VendorID=6
1884 2020/03/03 11:37:32 VendorError=2
1884 2020/03/03 11:37:32 File=AdlmIntLicenseMgr.cpp,Line=1532
1884 2020/03/03 11:37:32 AdlmIntError=1
8920 2020/03/03 11:43:17 Reason=Fatal error
8920 2020/03/03 11:43:17 ComputerName=i7-mk5-2015-32
8920 2020/03/03 11:43:17 OS=6.2.9200.
8920 2020/03/03 11:43:17 File=AdlmIntLicenseMgr.cpp,Line=1530
8920 2020/03/03 11:43:17 VendorID=6
8920 2020/03/03 11:43:17 VendorError=2
8920 2020/03/03 11:43:17 File=AdlmIntLicenseMgr.cpp,Line=1532
8920 2020/03/03 11:43:17 AdlmIntError=1
We're running out of ideas now so we'd like to know if you have more ideas about this.
Thank you very much for your help.
If you are using FLexLM licenses you should ignore the port 5053, this is only for RLM licenses.
Licenses only remove watermarks, that is all.
You should contact Autodesk Educational support
Hello Ashley,
We made a mistake, we are not using the port 5053. We are using the port 27001 and the port 27002 with the ADSKFLEX_LICENSE_FILE.
