Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HtoA search python in wrong path
10 REPLIES 10
Message 1 of 11
edenexposito
724 Views, 10 Replies
Hello, I'am in OSX
I have a problem due to HtoA is searching python.framework in wrong path (old Houdini version). How I can change it manually to ensure to point to correct path?
here console report:
I tried to install this Houdini version, and then HtoA found framework and render correctly in the other Houdini release..
Tags (1)
Labels (1)
10 REPLIES 10
Message 2 of 11
I can't tell from that screenshot whether it is HtoA-related or not. What library cannot be inserted?
Check Help > About Houdini > Show Details
Look for the environment variables
// Stephen Blair
// Arnold Renderer Support
Message 3 of 11
In show details all refers to 17.5.460
But something in someplace it's forcing to HtoA to search python framework on Houdini 18.0.287.
I tried to uninstall HtoA and Houdini with theirs uninstallers.. and install it again, but no luck. Something is forcing to HtoA to look wrong path. With Mantra all works...
Message 4 of 11
I search variables with printenv command and with hconfig.
None of these commands show paths that point to wrong version 18.0.287 ... all seems correct.
But something else is force to HtoA to search Python framework on wrong place...
Message 5 of 11
What does your houdini.env look like?
Can you post the Show Details from Houdini?
// Stephen Blair
Message 6 of 11
Sure i add a screenshot of both
Message 7 of 11
marklowe
in reply to: edenexposito
5.1.1 has the same problem for H17.5.460. Arnold looks for H18 files (not installed). I can’t render. OSX too.
Message 8 of 11
voklmun
Got same problem here.
I don't understand why HtoA keep referring to Houdini18.0.287
I'm using Houdini 10.0.461 , MacOS Catalina.
Message 9 of 11
This looks like a bug, thanks for reporting.
Please can you remove the line
darwin*) export DYLD_INSERT_LIBRARIES="/Applications/Houdini/Houdini18.0.287/Frameworks/Python.framework/Versions/2.7/lib/libpython2.7.dylib"
from the file
<htoa>/scripts/bin/hick
and let us know if this doesn't fix the issue.
Message 10 of 11
voklmun
in reply to: julian.hodgson
It seems to solve the problem. Everything works as expected.
Thank you!
Message 11 of 11
marklowe
this fixed the problem,
tested on H17.5.460 with htoa 5.2.0 (which has the same bug)
please fix it in 5.2.1 OSX
thank you
