HtoA - Renderview and render time low performance
I have a question about Arnold's performance between C4D and Houdini. Here the same scene with same setup + setting and C4D run so much faster than Houdini ( around 17 ~ 19 seconds ).
I'm using Houdini 18.0.416 with HtoA 5.2.1 and Cinema4D R21 with C4DtoA 3.0.3 running on macOS 10.15.4 ( Catalina ) on Macbook Pro 16.
The problem is C4D only takes 1~2s to generate the scene and Houdini takes at least 10s.
One more thing, in C4D when I change any parameter, Arnold updates instantly. But in Houdini, it only changes when I move lights or object around. If I drop down some shader node like Curvature or AO and plug it to the OUTPUT, I have to re-render to renderview and it takes too much time to generate the scene even the simplest one.
Is there any solution to speed up in Houdini ? I'm switching to Houdini to do all of my work now and it's really annoying to be slowed down while doing the lookdev.
BR,
