I'm running Houdini
19.5.303 py39 with HtoA
6.1.3.2 on linux Rocky 8.6.
If I launch Arnold in the same session as 3Delight, Redshift, V-Ray it seems to remove their Solaris viewport shading and/or lighting.
If I remove Arnold all the othere renderers work together and I can switch between them in the Solaris viewport along with Karma, Renderman, Storm etc no problem.
As soon as I introduce Arnold, either via a packages .json file or just adding the HOUDINI_PATH in the houdini.env then the others stop working.
Is this a known issue or is there a workaround for this?
EDIT: This only happens when V-Ray & Arnold are together, I posted this on the V-Ray forum also
Ant
