Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
HTOA 3.x.x instance render bug ?!
8 REPLIES 8
Message 1 of 9
iks2k
663 Views, 8 Replies
In previous version 2.2.3 when i use INSTANCE and point attribute "instance" with for example "/obj/geo1" and render - all ok! Htoa use "/obj/geo1" as instance and correct render, low memory, etc. In version 3.0.0(3.0.1) when i try render same scene or use same method - htoa quickly takes all my RAM... Finish ๐Ÿ˜ž
In new version something changed with instance or this is bug?
Thank you...
Tags (3)
Labels (3)
8 REPLIES 8
Message 2 of 9
Stephen.Blair
in reply to: iks2k
I just rendered a simple test with 100k instances with the Instance object. Do you have repro scene (as scene that reproduces the problem)?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
iks2k
in reply to: Stephen.Blair
Here is the scene for example: https://www.sendspace.com/file/z5gp81
Message 4 of 9
Stephen.Blair
in reply to: iks2k
Thanks. It rendered ok on my machine.
00:05:57 148MB | memory consumed in MB:
00:05:57 148MB | at startup 36.71
00:05:57 148MB | externally allocated 15.30
00:05:57 148MB | OpenVDB volume plugin 15.30
00:05:57 148MB | unaccounted 34.55
00:05:57 148MB | total peak 205.57
// Stephen Blair
Message 5 of 9
iks2k
First screenshot is 2.2.3 version - all render OK(!), Second - 3.0.0 - all memory occupied in few seconds, computer freeze and full finish ๐Ÿ˜ž
I tested on two different computers with Linux and Windows ...
The question remains open ...
Message 6 of 9
Stephen.Blair
in reply to: iks2k
And yet it was fine for me with HtoA 3.0.1
Can you post an Arnold log?
// Stephen Blair
Message 7 of 9
iks2k
in reply to: iks2k
Videos.
https://yadi.sk/d/xaQfFvhW3UroYj
2018-04-27 23-51-58.flv - htoa 3.0.1
2018-04-27 23-55-25.flv - htoa 2.2.4
This instances render may take 5-7 GB max, not 10,20,30...50, etc ... There is not fine.
Message 8 of 9
julian.hodgson
in reply to: iks2k
Thanks for the videos - can you please upload your repro scene as well?
Message 9 of 9
iks2k
in reply to: iks2k
