Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
H20.0.688 / HtoA 6.3.1.1 - Failing to generate .ass from Houdini rop on Deadline
5 REPLIES 5
apps88EMR
471 Views, 5 Replies
When we try to use HtoA for .688 in our usual setup, with vanilla arnold nodes in a new clean scene, we get this error when trying to generate .ass:
FailRenderException : Error: module 'htoa.imager' has no attribute 'ropImagerPresetMenu'
Any suggestions? Log and hip file are attached.
Thanks!
5 REPLIES 5
Stephen.Blair
in reply to: apps88EMR
That kind of error is almost aways an environment or setup problem.
In this case, I see
loading plugins from /mnt/Apps/htoa-6.2.4.2_r323c0ca_houdini-20.0.506/dso/../scripts/bin/../plugins ...
and then
libai.so already loaded
2024-06-04 18:26:27:  0: STDOUT: [htoa] HTOA environment variable already set to /mnt/Apps/htoa-6.3.1.1_r6f505f8_houdini-20.0.688
2024-06-04 18:26:28:  0: STDOUT: [htoa] HTOA environment variable already set to /mnt/Apps/htoa-6.3.1.1_r6f505f8_houdini-20.0.688
So it looks like the wrong HtoA for the installed Houdini version.
// Stephen Blair
// Arnold Renderer Support
apps88EMR
Good catch Stephen, we'll confirm our environment.
apps88EMR
So here's the weird part - this is the environment for the job on the farm:
PATH
/mnt/Apps/htoa-6.3.1.1_r6f505f8_houdini-20.0.688/scripts/bin:/mnt/Apps/hfs20.0.688/python/bin:/mnt/Apps/hfs20.0.688/bin:/mnt/Apps/hfs20.0.688/houdini/sbin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/sbin:/usr/local/sbin:/usr/sbin:/opt/rv-centos7-x86-64-7.9.0/bin:/usr/local/Nuke12.2v3:/opt/hfs18.5/bin:/opt/rv-centos7-x86-64-7.9.0/bin:/usr/local/Nuke12.2v3:/opt/hfs18.5/bin:/Volumes/user/laurence/.local/bin:/Volumes/user/laurence/bin:/bin:/usr/bin
PXR_PLUGINPATH_NAME
/mnt/Apps/htoa-6.3.1.1_r6f505f8_houdini-20.0.688/dso/usd_plugins
HTOA
HTOA_PLUGIN_PATH
/mnt/Apps/htoa-6.3.1.1_r6f505f8_houdini-20.0.688/scripts/plugins:/mnt/Apps/htoa-6.2.4.2_r323c0ca_houdini-20.0.506/scripts/plugins
You can see the errant plugin folder in HTOA_PLUGIN_PATH.  I searched our entire codebase, and no where do we set HTOA_PLUGIN_PATH.
Any clue how that is getting set?
Thanks!
apps88EMR
Ah it might be we are running the wrong Houdini on the farm. Stay tuned.
apps88EMR
Yup that was it. Deadline by default doesn't have executable paths for 0.0.X versions - we were using the wrong executable path.
