Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Changing subdivision iterations causes gray render
4 REPLIES 4
346 Views, 4 Replies
I am considering to purchase Arnold renderer for Houdini.
I have Houdini version 17.0.416
Arnold Renderer i downloaded is version 3.2.1-2711242
Issues i am having
1.)
https://youtu.be/2fdACD704Ao
Increasing Iterations to higher when 1 will cause gray render.
2.)
Often After changing some node connections renderer wont update correctly. have to close window and open window again and then it renders
3.) For some reason
Only way i to make character face lips and other areas that i painted in mari as (brighter color) will look more wet when i increase Specular IOR to 15 or 20
When it is 1.52 not much difference.
I added also some images and hip file.
I hope you can assist me.
Best regards
Tanel.
4 REPLIES 4
Stephen.Blair
Check the Arnold log. Looks for warnings or errors. Don't ignore any warnings about bounds padding.
For the Render View, the Arnold log should be in the Houdini Console.
For testing, use the same displacement with a Utility shader. Enable the Polywire overlay mode.
// Stephen Blair
// Arnold Renderer Support
Wen i start houdini i get this:
00:00:00 52MB | [rlm] error initializing license system: 00:00:00 52MB | [rlm] * Can't read license data (-102) 00:00:00 52MB | [clm] license server was not set (51) 00:00:00 52MB | [rlm] solidangle_LICENSE = (not set) 00:00:00 52MB | [rlm] RLM_LICENSE = (not set) 00:00:00 52MB | [clm] ADSKFLEX_LICENSE_FILE = (not set) 00:00:00 52MB | [clm] LM_LICENSE_FILE = (not set)
(I am using non licenced arnold) has watermarks.
As i wanted to see what result i can get with Arnold before i buy it.
When i now increase Iterations to 2 for example. I get:
00:00:07 2533MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1011.tx" 00:00:07 2533MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1012.tx" 00:00:07 2533MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1014.exr -v -u --unpremult --oiio 00:00:07 2533MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1013.tx" 00:00:07 2533MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1021.exr -v -u --unpremult --oiio 00:00:07 2533MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1014.tx" 00:00:07 2533MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1022.exr -v -u --unpremult --oiio 00:00:07 2533MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1023.exr -v -u --unpremult --oiio 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1021.tx" 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1024.exr -v -u --unpremult --oiio 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1023.tx" 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1022.tx" 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1031.exr -v -u --unpremult --oiio 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1024.tx" 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1032.exr -v -u --unpremult --oiio 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1033.exr -v -u --unpremult --oiio 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1031.tx" 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 1\KIHT1.1034.exr -v -u --unpremult --oiio 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1032.tx" 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1033.tx" 00:00:07 2534MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 1\KIHT1.1034.tx" 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1001.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2534MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1002.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2535MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1001.tx" 00:00:07 2535MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1003.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2535MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1002.tx" 00:00:07 2535MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1004.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2535MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1003.tx" 00:00:07 2535MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1011.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2535MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1004.tx" 00:00:07 2535MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1012.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2536MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1011.tx" 00:00:07 2536MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1013.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2536MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1014.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2536MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1012.tx" 00:00:07 2536MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1013.tx" 00:00:07 2536MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1021.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2537MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1022.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2537MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1014.tx" 00:00:07 2537MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1023.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2537MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1021.tx" 00:00:07 2538MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1024.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2538MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1022.tx" 00:00:07 2538MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1031.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2538MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1023.tx" 00:00:07 2538MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1024.tx" 00:00:07 2538MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1032.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2538MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1031.tx" 00:00:07 2538MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1033.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2538MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Spec maps\Base Color.1034.tif -v -u --unpremult --oiio --colorconvert "sRGB" "linear" 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1032.tx" 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1033.tx" 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Spec maps\Base Color.1034.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1001.exr -v -u --unpremult --oiio 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1002.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1001.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1003.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1002.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1004.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1003.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1011.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1004.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1012.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1011.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1013.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1012.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1014.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1013.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1021.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1014.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1022.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1021.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1023.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1022.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1024.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1023.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1031.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1024.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1032.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1031.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1033.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1032.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Kiht 3\KIHT3.1034.exr -v -u --unpremult --oiio 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1033.tx" 00:00:07 2539MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Kiht 3\KIHT3.1034.tx" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1001.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1002.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2539MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1003.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2540MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1001.tx" 00:00:07 2540MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1002.tx" 00:00:07 2540MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1004.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2540MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1003.tx" 00:00:07 2540MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1011.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2540MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1004.tx" 00:00:07 2540MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1012.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2541MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1011.tx" 00:00:07 2541MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1013.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2541MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1012.tx" 00:00:07 2541MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1013.tx" 00:00:07 2541MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1014.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2541MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1021.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2542MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1014.tx" 00:00:07 2542MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1022.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2542MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1023.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2542MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1021.tx" 00:00:07 2542MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1022.tx" 00:00:07 2542MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1024.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2542MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1023.tx" 00:00:07 2542MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1031.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2543MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1024.tx" 00:00:07 2543MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1032.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2543MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1031.tx" 00:00:07 2543MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1033.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2543MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1032.tx" 00:00:07 2543MB | [htoa.texture] AiMakeTx G:/Project Kerrigan Textures/Displacement\Displacement.1034.tif -v -u --unpremult --oiio --format exr -d half --colorconvert "sRGB" "linear" 00:00:07 2543MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1033.tx" 00:00:07 2543MB | [AiMakeTx] maketx: no update required for "G:/Project Kerrigan Textures/Displacement\Displacement.1034.tx" 00:00:07 2539MB | [htoa.texture] Converted 0 textures in 0:00:00.02 (64 skipped, 0 errors) 00:00:07 2531MB | [ass] writing scene to c:\users\tann\appdata\local\temp\houdini_temp\htoa_Tann\6296_918bf60b-3d81-497d-bdd7-674dc7b46a0e.ass (mask=0xFFFF) ... 00:00:07 2571MB | [ass] wrote 188573675 bytes, 18 nodes in 0:00.76 00:00:07 2531MB | 00:00:07 2531MB | releasing resources 00:00:07 2530MB | Arnold shutdown
and render was gray again long time but then suddenly it loaded.
And tested that if i increase the iteration more it stays gray longer (still gray, hoping it will render).
What is that lag before it actually starts to render?
I have 128 gb DDR4 CL14 timing ram
And AMD Threadripper 1950x
From where should i enable the polywire thing?
How to connect the utility node?
