Hello
I was trying to export .usd file with arnold scene exporter from cinema 4d to houdini.
But when I import exported .usd file in houdini materials with textures appears solid red. What should I do for to make textures appear correctly? I tried to put textures in same directory that usd file in and make same file path that cinema4d has but any file path couldn't help to to appear textures. Can you please help me to fix this?
You can see preview textures in the attachments. Thank you so much.
Hello
the only solution I could find for this problem is to make my usd exports as absolute paths. Then textures appears correctly. Is there any way to those relative paths?
