Arnold not rendering with Udims - houdini 17.5 - render region grey
phillips.a.adam
Message 1 of 8
phillips.a.adam
Arnold seems to have a real issue with rendering in the render scene or in a region once I load a displacement map across UDIMs. The maps should work fine with the %(UDIM(d setup, i'm basically transferring everything from rendering in Mantra to rendering in Arnold due to Mantra's excessive hunger for ram.It's really not the biggest scene in the world. but as soon as I plug in a 4 UDIM displacement Arnold IPR doesn't generate anything. I've set my geometry to only 1 subdivision iteration.
My CPU is a Ryzen Threadripper 2950x - 16 core - which should at least be able to handle a basic setup like this.
Replies (7)
Message 2 of 8
phillips.a.adam
Actually - I'd like to add that it's not jdisplacement. It seems to be ANY UDIM textures. I'm working on windows 10 also.
Message 3 of 8
Stephen.Blair
@Adam Phillips udims for surface shading work for me
didn't try displacement yet
// Stephen Blair
// Arnold Renderer Support
Message 4 of 8
Stephen.Blair
You have to use the <udim> tag
// Stephen Blair
Message 5 of 8
phillips.a.adam
Thanks...can you point me to an example if %(UDIM)d doesn't work? thanks @Stephen Blair
Message 6 of 8
Stephen.Blair
You use <udim> in the Filename, like this:
$HIP/colortiles.<udim>.png
That will load colortiles.1001.png, colortiles.1002.png, and so on
// Stephen Blair
Message 7 of 8
phillips.a.adam
Thanks @Stephen Blair that worked a Treat!
Message 8 of 8
antoinebourguelle
Thanks for your post. Are you rendering with Arnold ?
