Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Arnold not rendering textures in Houdini
will180
Observer Observer
will180
Observer
Observer
So as per the title, the textures are showing in the viewer and if I use Manta or Karma (the built-in Houdini render engines), but not when rendering in out of Arnold.
I imported lots of .glTF from sketchfab.com and they all have the same issue, but not with Manta or Karma.
I also tried all the models from here, and none of them work with Arnold!
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_houdini_tutorials_ah_Learning_Scenes_html
I have posted this on SideFX forum too:
https://www.sidefx.com/forum/topic/93957/?page=1#post-410145
Will
Stephen.Blair
glTF is not supported by Arnold
Those screenshots look like there's no material assigned to geometry. Can you get an Arnold log for a render?
// Stephen Blair
// Arnold Renderer Support
will180
Observer
Observer
"glTF is not supported by Arnold"
Wow, thanks, that's one problem 'solved'.
"Can you get an Arnold log for a render?"
Please see attached.
Thanks again.
Will
Stephen.Blair
I don't see any materials or textures.
There are 2 utility shader nodes, but those are the default shaders created by HtoA.
Normally I would expect to see some standard_surface shaders, and for textures, some image nodes.
00:00:00   229MB         | there are 2 lights and 71 objects:
00:00:00   229MB         |       2 persp_camera
00:00:00   229MB         |       2 point_light
00:00:00   229MB         |       2 utility
00:00:00   229MB         |       2 box_filter
00:00:00   229MB         |       1 gaussian_filter
00:00:00   229MB         |      70 polymesh
00:00:00   229MB         |       2 list_aggregate
00:00:00   229MB         |       3 color_manager_ocio
00:00:00   229MB         |       1 driver_houdini
// Stephen Blair
will180
Observer
Observer
Thanks for looking.
