Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold constantly freezing on "Updating Nodes"
14 REPLIES 14
Message 1 of 15
am_wilkins
1138 Views, 14 Replies
I've noticed that Arnold keep freezing on "Updating Node" on both CPU and GPU.
Usually it will sit forever at this point and any while the Houdini scene remains functional, any attempt to interrupt the render will cause Houdini to freeze and require and "End Task".
Example below, the scene should cache (Restart Arnold or new render) within 5 seconds, however left for over 10mins nothing happens.
Trying to restart render, switch back to OpenGL, etc. will cause Houdini to freeze.
Attempt at interrupt:
all the best,
amwilkins
Houdini Core Version 20.0.590
Arnold Core: 7.2.5.2
HotA: 6.2.5.2
CPU: AMD Ryzen TR 3990x
RAM: 128GB
GPU: NVIDIA RTX A4000
OS: Windows
14 REPLIES 14
Message 2 of 15
Stephen.Blair
in reply to: am_wilkins
Hi Andrew
I had a similar report from another user, and I've been trying to repro. But no luck with that so far.
I'm not sure what's in the scene that requires that much "updating nodes"
Maybe you could send a log from another render that gives me an idea? DM it if you prefer, or use the support channel: support@arnoldrenderer.com
// Stephen Blair
// Arnold Renderer Support
Message 3 of 15
am_wilkins
in reply to: Stephen.Blair
I can try to provide more information. Proper logs are still not always successful for me, especially though Husk.
The scene itself is actually quite small and basic, those nodes are likely some geo based grass instanced to points.
thanks,
amwilkins
Message 4 of 15
Stephen.Blair
On Windows, if you set HOUDINI_TEXT_CONSOLE=1, you should get all the Arnold log in a command prompt window. I have this in my package file:
        {"HOUDINI_TEXT_CONSOLE": [
                    "value": "1",
                    "method": "append"
// Stephen Blair
Message 5 of 15
am_wilkins
Thanks, I'll have to try this out cause not seeing logs is frustrating.
amwilkins
ps. in initial testing Redshift automatically always saves a log out to a file, which is cool to see.
Maybe some functionality like that will help you get logs from users in the future.
Message 6 of 15
am_wilkins
I caught a scene that was doing this, however the logs don't seem very useful:
03:26:32 12338MB         |  OIDN Device Enum, Device 0 : NVIDIA RTX A4000
03:26:32 12339MB         |  OIDN Device Enum, Device 1 : AMD Ryzen Threadripper 3990X 64-Core Processor
03:26:32 12341MB         |  default OIDN device created
03:26:32 12343MB         |  Selected OIDN Device Type: CUDA
03:26:33 12678MB         |  creating root object list ...
03:26:33 12678MB         |  the following procedurals were initialized serially:
03:26:33 12678MB         |     instancer (27 instances)
03:26:33 12678MB         | node initialization done in 0:07.44 (multithreaded)
03:26:33 12678MB         | updating 305710 nodes
It was rendering fine, I stopped the render, made some adjustments and started it again. Then it just sits on " Updating all 305710 nodes" indefinitely until I'm force to try cancel the render. In which case Houdini freezes.
Message 7 of 15
francoislord
Here are 1 million PigHeads instanced on a grid.
In houdini-19.5.752 with htoa-6.2.4.1.
Smooth updates in the IPR when orbiting and panning the camera.
Here is the exact same USD file in houdini-20.0.590 with htoa-6.2.5.2.
The time to first pixel is about the same, but the rendering speed is slower, and there's a significant lag when orbiting the camera, and an even greater lag when panning the camera.
This is consistant in all scenes.
F
Message 8 of 15
francoislord
@Stephen.Blair can you aknowledge this? Can you reproduce on your side?
Thanks!
Message 9 of 15
No, I don't have a repro
// Stephen Blair
Message 10 of 15
klaus.skovbo
I have the same issue on Houdini 20.0.653 and HtoA 6.3.1.0 where if I tumble the camera around the scene I get "Updating xxxx nodes" in the Solaris viewport.  The scene I am rendering have millions of grass instances. Exact same issue as the videos @francoislord  posted above. - If I disable the pointInstancer the viewport works as expected.
Was a solution found to this problem?
Message 11 of 15
thiago.ize
There's been a bunch of releases since htoa 6.3.1 (currently we're at 6.3.3.1). It's possible one of these might have fixed this issue? If not, then a repro would help.
Message 12 of 15
francoislord
I just tried it with Houdini 20.5 and HtoA 6.3.3.1 and the refresh rate is much better. It's still a lot slower than Karma, but it's much better than it was a few months ago.
Message 13 of 15
Stephen.Blair
I don't see any "updating nodes" messages, but I can see the IPR update (for example, for camera moves) is much slower in the the newer Houdini/HtoA
// Stephen Blair
Message 14 of 15
klaus.skovbo
Hey,
I updated to 20.5 and HtoA 6.3.3.1 - It fixed the "Updating Nodes". However, I now see a "initializing light accel" between each iteration of sampling. This is with the instances activated (again millions of instances). If I deactivate the instances, the viewport interaction is super fast and responsive.
Message 15 of 15
I can't reproduce any problems like that.
Not unless I have HDARNOLD_DEBUG_SCENE set (that writes out a debug ass file for every render).
// Stephen Blair
