There may be some bugs in AOVs
895793442
895793442
When no AOVs are activated, the rendering result is correct. As shown in the attachment, its color space is correct.
After activating AOVs, for example, if I activate P channel or N channel, the rendering result is incorrect and the color space is incorrect.
I have tried many AOVs settings, and found that not only the P channel and N channel have incorrect rendering results, but also the object mask tag will cause incorrect rendering results.
Is this a bug?
peter_horvath
Looks like a bug indeed. Thanks for reporting, will be fixed in the next release.
Meanwhile you can change the Cinema 4D color manager in the Project Settings to OpenColorIO and the color manager in the Arnold Render Settings to use the Cinema color manager, as recommended here: https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_cinema_4d_ci_Rendering_ci_ACES_Workflow_ht...
// Peter Horvath
// C4DtoA developer
Thank you for your answer. According to your settings, C4D can output pictures correctly. Thank you very much
peter_horvath
Should be fixed in C4DtoA 4.5.1.2.
// Peter Horvath
// C4DtoA developer
