Texture showing in IPR but not in the final render
eddi_fuhrmann
eddi_fuhrmann
Hello.
I am doing a cloth animation at the moment and i have some errors here: It´s actually a simple material which is done with 2 standart surfacae shaders which are controled by a vertex map-
Everything looks fine when i preview it in the IPR but one texture is missing in the rendered version. the od thing is it´s not happening every where but only at some spots...checked the cameras and everything but i am pretty clueless here...
Stephen.Blair
The IPR is a little different environment, sometimes something will work there but not in the "real" render.
Red is the color for texture errors.
Can you get an Arnold log?
https://docs.arnoldrenderer.com/display/A5AFCUG/Log
// Stephen Blair
// Arnold Renderer Support
eddi_fuhrmann
i found this in the console
[c4dtoa] 00:00:03 9041MB WARNING | opaque is deprecated: opaque is off for geometry "/Subdivision_Surface/Cloth_Surface/Polygon", but there is no opacity metadata for some of its shaders
[c4dtoa] 00:00:21 10509MB WARNING | opaque is deprecated: opaque is off for geometry "/Subdivision_Surface/Cloth_Surface/Polygon", but there is no opacity metadata for some of its shaders
[c4dtoa] 00:00:21 10578MB WARNING | opaque is deprecated: opaque is off for geometry "/Subdivision_Surface/Cloth_Surface/Polygon", but there is no opacity metadata for some of its shaders
[c4dtoa] 00:00:22 10568MB WARNING | opaque is deprecated: opaque is off for geometry "/Subdivision_Surface/Cloth_Surface/Polygon", but there is no opacity metadata for some of its shaders
[c4dtoa] 00:00:22 10569MB WARNING | opaque is deprecated: opaque is off for geometry "/Subdivision_Surface/Cloth_Surface/Polygon", but there is no opacity metadata for some of its shaders
[c4dtoa] 00:00:23 10579MB WARNING | opaque is deprecated: opaque is off for geometry "/Subdivision_Surface/Cloth_Surface/Polygon", but there is no opacity metadata for some of its shaders
eddi_fuhrmann
*** RENDER LOG FILE ***
Renderjob started on 03/18/2021 at 09:27:38
File: C:\Cinema\Dateien\aktuell\15.03.20_Balloon2\Balloon_2.c4d
Cinema 4D 23.110
Frames: 1
CPUs: 24
Resolution: 1080x1350
Antialiasing: Edge
Field rendering: Off
Motion Blur: Off
Reflections: On
Transparency: On
Shadows: On
Volume effects: On
Alpha channel: Off
Output format: Single frames
Rendertime: 00:03:16
Renderjob finished on 03/18/2021 at 09:30:55
Stephen.Blair
Here's how to get an Arnold log
// Stephen Blair
