small SSS scale values not working with GPU render
Brian_Re
Brian_Re
Hi there!
I found an issue with Arnold GPU rendering. The issue is that SSS scaling does not work when using small values in GPU rendering.
I've tried a few tests (see the image below), but the problem still exists. I'm rendering a real-world-scale cookie in this test. The cookie measures about 18 centimeters in length. It appears OK when I render it with the CPU. However, when I switch to the GPU, the SSS scale stops working after a specific value (which varies by scene). I tried all three of Arnold's most recent releases, and the problem persists. I also tested five different scenes, and the problem is the same: when rendering with GPU there is a bug with the SSS scale .
Stephen.Blair
I did a quick test and couldn't repro
Is this cookie at or near the world origin, or far away?
Displacement / texture ?
GPU doesn't support diffusion and will switch to randomwalk v2
// Stephen Blair
// Arnold Renderer Support
Brian_Re
Did you use a small object like a 3 cm cube? because I'm seeing this issue on multiple machines. anyways. The cookie is in the center of origin, and it has displacement.
Someone already mentioned this problem before here: SSS Issue in GPU mode (Randomwalk V2)
Stephen.Blair
Units in Arnold are arbitrary. So I did an 18 unit cube in Maya where Maya defaults to cm
I'll make it smaller.
// Stephen Blair
peter_horvath
While Maya uses cm as the default unit, scenes are exported from Cinema 4D with meter as the default, therefore values are smaller. This is a known GPU numerical precision issue, as mentioned in the linked thread, and tracked internally with ticket ARNOLD-11163. Hasn't been fixed yet, unfortunately.
As a workaround, you can try to change the Export Scale to 1 centimeter in the Arnold Render Settings under the System tab. That will basically scale up your Arnold scene.
// Peter Horvath
// C4DtoA developer
