Random spline thickness
paul.clements
paul.clements
I have a single object which is many individual splines along a flat surface.
Is it possible to give each spline a random thickness? Each spline should be uniform in thickness but just different from each other... Any help is much appreciated!
peter_horvath
There's no way to randomize the radius currently, I'm afraid. It would be a nice addition in a future version though. Your only option currently is using a tool where you can control thickness on the geometry level (e.g. xp trails).
// Peter Horvath
// C4DtoA developer
paul.clements
Thanks Peter. I had another question also re. curves....
Is it possible to colour the curves in order? So curve 1 is white and curve 100 is black? I have been experimenting with curve_id but no success as yet.
peter_horvath
That should be it. user_data_int with curve_id as the attribute, connected to a range shader to map [0, N] to [0, 1]. The order is how the splines defined in the object. You might need a ramp as well to set from white to black.
// Peter Horvath
// C4DtoA developer
paul.clements
That has worked brilliantly, I was missing the range shader. Much appreciated, thanks Peter
peter_horvath
Thickness can now be randomized per spline in C4DtoA 4.2.3.
// Peter Horvath
// C4DtoA developer
