opaque is deprecated warning
michaelmatthews1
Message 1 of 9
michaelmatthews1
Every time I open the Arnold IPR window I start getting warning messages saying "opaque is deprecated". What does this mean and how can I address it? Thanks!
Michael
Arnold IPR started at Sun Oct 31 11:54:27 2021
[c4dtoa] 00:00:10 3502MB WARNING | opaque is deprecated: opaque is off for geometry "/Null/Surface/Loft|Loft", but there is no opacity metadata for some of its shaders
[c4dtoa] 00:00:10 3502MB WARNING | opaque is deprecated: opaque is off for geometry "/Null/Surface/Loft_7|Loft", but there is no opacity metadata for some of its shaders
Replies (8)
Message 2 of 9
Stephen.Blair
Select the Opaque check box for those Loft objects.
That Opaque check box is no longer used. Instead, "smart opaque" can figure out whether or not an object is opaque by looking at the surface shaders on the object.
But if you put some other type of shader, like say a Color Correct, on an object, and turn off Opaque, you get that warning.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
maxtarpini
Do you know if this has been updated also for custom shaders that does transparency ? Maybe there's an inner flag or something available now ? Last time (6.2 I think) I checked it was not and I had to un-check opaque to have transparency.
Message 4 of 9
Stephen.Blair
A custom shader would have to provide the opacity metadata, as shown here:
https://docs.arnoldrenderer.com/display/A5ARP/5.3.0.0
Is that what you're doing?
// Stephen Blair
Message 5 of 9
maxtarpini
Exactly what I was looking for, thanks !
Message 6 of 9
agustin.gonzalezA9F92
hi there guys,
can you guys point me to the doc example that shows how to provide the opacity metadata?
the documentation changes and the link from Stephen don't work anymore.
thanks!
Message 7 of 9
peter_horvath
You can find it in the Arnold 5.3.0.0 release notes.
The relevant bit:
// - \`opacity_term\` tags a parameter that is opaque when equal to 1 or (1,1,1)
// - \`transparency_term\` tags a parameter that is opaque when equal to 0 or (0,0,0)
// The additional integer brackets together terms with the same number.
// This metadata setup from standard_surface:
AiMetaDataSetInt(node, "opacity", "opacity_term", 0);
AiMetaDataSetInt(node, "transmission", "transparency_term", 1);
AiMetaDataSetInt(node, "transmission_color", "transparency_term", 1);
AiMetaDataSetInt(node, "metalness", "opacity_term", 1);
// is equivalent to setting:
// opaque = (opacity == AI_WHITE) && (transmission == 0 || transmission_color == AI_BLACK || metalness == 1);
// Peter Horvath
// C4DtoA developer
Message 8 of 9
ssjenforcer191191191
I am getting this warning for 5 of my instances every time I use IPR regardless if Opaque is checked for the scatter object or not.
Does this warning even mean anything?
Message 9 of 9
peter_horvath
The instancer always overrides the opaque flag of the instances hence the warning. (You see 5 messages, because that's the limit of warning messages set in the render settings by default.) The warning itself is harmless, you can ignore it. This parameter was deprecated when the smart-opaque feature was introduced. There are some corner cases where the opaque flag can still be useful, but normally it's not used anymore.
// Peter Horvath
// C4DtoA developer
