Opacity/Transmission with Image
simonEPZ3S
simonEPZ3S
Hoping someone can help me out...
I have a simple plain with a Mesh light tag applied. The mesh light is using a shader network.
The shader network is an image node and color correction.
I want to be able to adjust the transmission (or is it opacity?) of the image so I still see the image but I am also able to see through the plane to what is behind it. Essentially a semi transparent video screen.
Is this possible?
Any tips appreciated 🙂
peter.horvath6V6K3
What about using the emission channel of the standard_surface shader instead of a mesh light?
simonEPZ3S
Thanks for the speedy response Peter...much appreciated.
I did think about that but after seeing the user guide mention the poorer performance (more noise) with emission vs mesh light I wanted to avoid the emission route.
I also have multiple objects that need to be tweaked and using the mesh light allows me to use the Light Manager which I find very useful.
Is the emission method my only option?
peter.horvath6V6K3
I think that's the only option at the moment, sorry.
simonEPZ3S
Thanks for clarifying Peter.
Hopefully in the future a "transmission" slider or something similar will appear under the Mesh Light 🙂
