Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Object with transmission hides texture of object below, see image in comments.
3 REPLIES 3
298 Views, 3 Replies
See attached image, for some reason this transparent object is hiding the image texture beneath.
The texture with the text/linework is set to opacity cutout and is referencing a matte via utility material.
Any help would be greatly appreciated
Tags (2)
Labels (2)
3 REPLIES 3
I just want the glass to act normally and be able to see the linework beyond the glass. played with the depth and IOR with no luck, tried alpha stacking on the glass object but not sure what im really looking for there.
jankarl.exe
Are you sure you have the arnold tag in there with the *opaque* ticked off?
peter.horvath6V6K3
Can you show your shader network? Or share a simple example scene?
