Stephen:
I ran the wizard to install this updated license server, selecting the new 2020 license it asked for, but it still isn't working in R21. Not only that, but it broke my older C4DtoA install that was working fine in R20. Not good.
My system had been set up to automatically launch the old license server upon boot on my Mac Pro. After restarting, the Terminal window appears to be showing a problem.
Last login: Thu Apr 23 12:25:50 on console
Cannot open "/usr/local/flexnetserver/solidangle.log" as log file (1)
freopen: Permission denied
MacPro-12Core:~ ShawnM$
I have no idea what to do in Terminal to correct this. When replying please assume you're talking to someone who knows almost nothing about working in Terminal.
I see that Sebastian Stanek on the C4DtoA email group had a similar problem today. Presumably he installed the newer license server and "killed all flexera processes and restarted the license servers." I assume restarting my machine restarted the license server(s), but I have no idea what's actually running now that I've presumably installed the latest version. Are two running now? Does the new install overwrite the old one? Beats me.
Diagnostic logs from the Arnold License Manager:
License diagnostics executed at 2020-04-23 12:39:15
Single-user Licensing Version: 10.1.1.66
kick -nostdin -v 1 -i /dev/null (0.60 sec)
00:00:00 64MB | log started Thu Apr 23 12:39:15 2020
00:00:00 64MB | Arnold 6.0.3.0 [991b08e9] darwin clang-9.0.1 oiio-2.2.1 osl-1.11.0 vdb-4.0.0 clm-1.1.2.132 rlm-12.4.2 2020/04/17 09:08:53
00:00:00 64MB | running on MacPro-12Core.local, pid=957
00:00:00 64MB | 2 x Intel(R) Xeon(R) CPU X5650 @ 2.67GHz (12 cores, 24 logical) with 32768MB
00:00:00 64MB | macOS 10.13.6 "High Sierra", Darwin kernel 17.7.0
00:00:00 64MB | soft limit for open files raised from 10238 to 10238
00:00:00 64MB |
00:00:00 64MB | loading plugins from /Applications/Maxon Cinema 4D R21/arnold/bin/./../plugins ...
00:00:00 64MB | loaded 5 plugins from 3 lib(s) in 0:00.02
00:00:00 64MB | [kick] command: /Applications/Maxon Cinema 4D R21/arnold/bin/kick -nostdin -v 1 -i /dev/null
00:00:00 64MB | loading plugins from . ...
00:00:00 64MB | no plugins loaded
00:00:00 65MB | [ass] loading /dev/null ...
00:00:00 65MB | [ass] read 0 bytes, 0 nodes in 0:00.00
00:00:00 65MB |
00:00:00 65MB | authorizing with license manager: network ...
00:00:00 67MB WARNING | rendering with watermarks because of failed authorization:
00:00:00 67MB | [clm.v1] generic license checkout error (22)
00:00:00 67MB | environment variables:
00:00:00 67MB | ARNOLD_LICENSE_ORDER = (not set)
00:00:00 67MB | ARNOLD_LICENSE_MANAGER = (not set)
00:00:00 67MB | [rlm] solidangle_LICENSE = (not set)
00:00:00 67MB | [rlm] RLM_LICENSE = (not set)
00:00:00 67MB | [clm] ADSKFLEX_LICENSE_FILE = @localhost
00:00:00 67MB | [clm] LM_LICENSE_FILE = (not set)
00:00:00 67MB |
00:00:00 67MB |
00:00:00 67MB | releasing resources
00:00:00 67MB | Arnold shutdown
kick -licensecheck (0.67 sec)
RLM DEBUG for product "arnold"
0 product instances found
Could not find any license files, please check the license server, the license may be expired
Please contact [email protected]
environment:
solidangle_LICENSE = (null)
RLM_LICENSE = (null)
lmutil lmstat -S adskflex -a -c @localhost -f 87287ARNOL_2020_0F (0.04 sec)
lmutil - Copyright (c) 1989-2018 Flexera. All Rights Reserved.
Flexible License Manager status on Thu 4/23/2020 12:39
License server status: 27000@localhost
License file(s) on localhost: /usr/local/flexnetserver/licenses/Localhost406c8fb8f6cc.lic:
localhost: license server UP v11.16.2
Vendor daemon status (on MacPro-12Core.local):
adskflex: The desired vendor daemon is down. (-97,121)
rlmutil rlmhostid -q ether (0.04 sec)
406c8fb8f6cc 406c8fb965ed 44d8846deaa8
FlexLM environment (0.00 sec)
ADSKFLEX_LICENSE_FILE (local env) = @localhost
ADSKFLEX_LICENSE_FILE (global user env) = @localhost
Adlm FlexNET cache = @localhost
Adlm FlexNET cache location = /Users/ShawnM/.flexlmrc
Thank you.
Shawn Marshall
Marshall Arts Motion Graphics
