Multipass not showing in C4D R25 Render Settings
adampyburn
Observer Observer
adampyburn
Observer
Observer
Hi there. I'm having an issue where the multipass options aren't displayed correctly in my render settings. If I click on a multipass item it's settings appear on the right side, but the tab isn't added to the column on the left, so I can't see what has been added or adjust their settings.
In the example below, I've clicked on Object Buffer from the Multipass dropdown. It's showing the Object Buffer setting on the right, but has not added the matching tab on the left, even though I've checked to save Multipass images in the Save Settings.
I've done Multipass renders a lot and this is the first time I'm seeing the issue.
I'm running MacOS 12.2.1 on a 2017 iMac
Thanks for any ideas!
peter.horvath6V6K3
Arnold does not support the native passes, like the Object Buffer, it has it's own AOV system and settings: https://docs.arnoldrenderer.com/display/A5AFCUG/AOVs
To render out masks, like the object buffer, you can use the Arnold Object Mask tag: https://docs.arnoldrenderer.com/display/A5AFCUG/Object+Mask
adampyburn
Observer
Observer
Ahh, that makes a lot of sense. Can't believe I'm just realizing that.
I guess all of my multipass and object buffer renders were with C4D Standard.
Thanks Peter!
