IPR Window Causing Spinning Ball on Mac?
Jacqueline_Dessel
Jacqueline_Dessel
Just installed Cinema 4D r19 and installed the latest version of Arnold, both tonight. Upon opening Cinema everything is fine- until I call up the IPR window. I immediately get the spinning ball (I'm on a Mac) and can't do anything. It just hangs up indefinitely. I've restarted C4D numerous times, rebooted, trashed the prefs, all to no avail. Any suggestions would be greatly appreciated.
Replies (7)
peter.horvath6V6K3
Does it happen in an empty scene as well? Do other parts of the plugin work (e.g. Light Manager window)? What's your R19 version exactly?
Jacqueline_Dessel
Hi Peter, thank you for your reply. It happens in both an empty scene as well as a working scene. Everything else seems to be working fine, including the Light Manager window. I'm using C4D r19.024
Jacqueline_Dessel
Also- I'm using Arnold 5.0.2.4 which uses IPR Window v2.2.3
peter.horvath6V6K3
One more question, do you have the same issue with C4DtoA 2.2.2?
Jacqueline_Dessel
I haven't used 2.2.2, this version is the first version I've downloaded.
peter.horvath6V6K3
But could you try to install 2.2.2? There was a change in 2.2.3 related to the IPR window, I wonder if that's causing the trouble.
Jacqueline_Dessel
I'm in contact with Arnold support and have just asked them to provide a link to a previous version's installation file. Thank you again for your help.
