How to texture hair length when you "Export UV" in C4D?
edenexposito
edenexposito
How I can control hair color from root to tip (Texture along V) at same time when I had applied a texture to create a color fur pattern ("Export UV")?. Here an image
peter.horvath6V6K3
The position along the length (from 0 to 1) is stored in the barycentric v coordinate (bv) which you can read via the state_float shader.
For example in the following network a ramp shader is controlled by bv (select 'custom' type in the ramp) to interpolate between a static color and a texture (Export UVs is enabled):
edenexposito
Thanks! Works like a charm
lamarKPDHG
>>>For example in the following network a ramp shader is controlled by bv (select 'custom' type in the ramp) to interpolate between a static color and a texture (Export UVs is enabled):<<<
If you wanted to simply use the entire color of the image would you then plug the image into both ramp colors?
Also, What happens to the base color in the standard hair shader in this type of setup?
I ask because I'm trying to do this with grass and following your advice to the letter brings some dark roots and results that aren't as good as the previous technique in Arnold.
peter.horvath6V6K3
The ramp setup interpolates between Color 1 and Color 2 from root to top. If you just want to use the texture through the whole curve then no need for the ramp, simply connect the texture to the Diffuse Color.
In this setup the the Diffuse Weight controls the diffuse contribution. 1 means fully diffuse scattering and the Base color has no effect.
