Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Gobo chromatic abberation?
4 REPLIES 4
AJUKking
1019 Views, 4 Replies
Is it possible to get a chromatic aberration effect on a texture that is input into the Slide map of the gobo node?
For example I have a black and white texture to help fake water caustics: caustics-001.png
The spot light emitted this gobo texture: gobo.png
Similar to what I want (mockup in photoshop): gobo-chrabb.png Ignore the edges of the plane since I just shifted the rgb channels of the whole image over a few pixels.
Can I get this effect on the texture natively in Arnold C4D?
Thanks!
Tags (3)
Labels (3)
4 REPLIES 4
lee_griggs
in reply to: AJUKking
You can use Shuffle with Cell Noise to do this. Example here.
Lee Griggs
Arnold rendering specialist
AUTODESK
AJUKking
in reply to: lee_griggs
Thanks, Lee. I've read through the example. Unfortunately I've gotten stuck at the end because it specifies to connect some nodes into the R, G, and B inputs of the Shuffle node but these only exist in the MtoA, not C4DtoA. I'm sure there's just a quick and easy C4DtoA equivalent for this but I'm too tired to figure it out right now. I'll try tomorrow.
Use the float_to_rgb shader.
Works great now, thank you!
