Getting semi transparency in the alpha channel on semitranparent objects?
demodunk
Message 1 of 10
demodunk
So, I have a plastic helmet that is transparent plastic with an IOR of 1,2.
How do I get the alpha channel to not be a black and white cutout but taking the refraction and reflections in consideration?
The manual says to use "opacity" for the the opacity to show up in the alpha channel but the only opacity option is the "cut out opacity" in the geometry tab and that's not what I'm after.
Replies (9)
Message 2 of 10
lee_griggs
Transmit AOVs
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 10
demodunk
Wow, thank's Lee! Exactly what I was looking for!
Message 4 of 10
demodunk
Seems that this won't work with an Arnold sky though. Even if I set the camera to 0 in the main tab.
Arnold seems to recognize the Arnold Sky as a background no matter what...
Message 5 of 10
lee_griggs
Skydome light?
Lee Griggs
AUTODESK
Message 6 of 10
demodunk
No I use an HDR texture via HDR-link.
Message 7 of 10
demodunk
The only workaround I have right now is to render the beaty and then disable Arnold sky and render the alpha.
Message 8 of 10
Stephen.Blair
You have to set Transmission to 0 for the skydome light (you're using an HDR? Then you must be using a skydome light, no?)
// Stephen Blair
// Arnold Renderer Support
Message 9 of 10
demodunk
No, I use Arnold Sky in texture mode. If I was to set transmission to 0 on it, the transparent object won' see that light.
Message 10 of 10
demodunk
Hey! It works when using a Sky dome instead, Awesome!
Thank's a million for the help!
