Fracture Voronoi object not rendering in Cinema 4D why ?
Message 1 of 14
Hi Everyone,
My question is really simple, since few days, when I would like to render an object with a fracture voronoi, this one isn't rendered in the final output... It's ok with the IPR… but not in the final render… someone knows why?
I'm using C4D R19 + Arnold 2.3.1.1
Cheers,
Mirko
Replies (13)
Message 2 of 14
I had the same error recently.
I was able to trace it to Arnold not "understanding" the subdivision surface i placed my object in.
Hence i had to bake the object with the subdivision as one whole object, then i applied an Arnold parameter tag. I then enabled the "catclark" option under the subdivision tab in the Arnold tag i applied
I hope this helps
Message 3 of 14
peter.horvath6V6K3
Do you have a simple scene showing the problem? Did it start with 2.3.0 or do you have the issue in previous release as well?
Message 4 of 14
@kennybadex kennybadex thanks for the tips, but not working on my scene 😞
@Peter Horvath here the scene https://www.dropbox.com/s/8zje5sw8ve4445b/Cesar2.c4d.zip?dl=0, it's starts using 2.3.1.1 … first time I have this issue,
Message 5 of 14
peter.horvath6V6K3
I can't download the scene: "This link is temporarily disabled. The person who shared it hit their daily limit of traffic or downloads."
Message 6 of 14
Message 7 of 14
peter.horvath6V6K3
Your scene renders fine here, the only thing I changed is to replace the missing textures. Tried with Cinema 4D R19, C4DtoA 2.3.1.1 on win and osx. Do you have any error in the log (console) maybe? What's your C4D version exactly? R19.053? Win or osx?
Message 8 of 14
@Peter Horvath oO I'm using R19.053 on mac OS high Sierra + Arnold C4DtoA 2.3.1.1
I have some warning
in the log, when I use the IPR its ok but not with the render engine…
Message 9 of 14
peter.horvath6V6K3
That's strange, it seems the volume and shader plugins are not loaded, which explains why you can not render. However the IPR should not work either. Is everything alright with your installation? Can you try to reinstall the plugin?
Message 10 of 14
@Peter Horvath , I try to reinstall it, like four times… change nothing 😞 I don't know why…
this is really disapointing
Message 11 of 14
peter.horvath6V6K3
I was just checking your log again and those plugins (volume_openvdb.dylib, tfd.dylib, common_shaders.dylib) are from an old install (C4DtoA 1.x / Arnold 4), so it must be a corrupt installation. Try to manually delete the /Applications/MAXON/Cinema 4D R19/plugins/C4DtoA folder first, and than install again.
Message 12 of 14
peter.horvath6V6K3
You might also have to remove the /Applications/MAXON/Cinema 4D R19/arnold folder.
Message 13 of 14
Mohamed_Sahil
my answer will be very strange. but I was facing this issue. try to put into cloner your Voronoi fracture and give 1 count, it will stay as the original. then render it. cheers
Message 14 of 14
yurrryme
Community Visitor
Community Visitor
Awesome, thanks, now it works!
