Displacement disappearing
JakobAppleby
Message 1 of 9
JakobAppleby
I have this text imprinted on a simple geometry, im using a simple texture to displace it and everything is fine up until frame 277 where suddenly the displacement is gone.
I tried rendering out the texture that gets fed into the displacement straight to the beauty output of the shader and it shows it correctly.
The texture is using a cubic projection. And the gold text over is a stacked material with displacement, but that doesn't seem do affect it in any ways
Please see attachment where you first see the render that has 2 frames right and then the displacement is gone, then you see the texture of the displacement
(Problem is the same on gpu/cpu)
https://www.dropbox.com/s/ruq7tga9jz5s8ah/displacementproblem.mp4?dl=0
edit: It almost seems like it has something to do with it being rotated in space, had a previous version where it never got to the rotations it has now, and didnt get that problem
Replies (8)
Message 2 of 9
Stephen.Blair
Did you check the Arnold log?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
JakobAppleby
Yes, but now that you mention it i did not change it to debug mode. Might say some
Edit: Nah nothing
Message 4 of 9
Stephen.Blair
Debug is rarely necessary. Info is usually enough
// Stephen Blair
Message 5 of 9
JakobAppleby
Well i thought it had something to do with the cubic projection, and i fixed it by using a flat projection. dont know why the cubic one bugged out on the rotation, while the texture would still be correct
Message 6 of 9
peter.horvath6V6K3
I'd take a look if you could send me the scene.
Message 7 of 9
JakobAppleby
To reproduce this; First have the object rotated less than 44 degrees on Z and see that the displacement works. Then change it to 46 or more degrees and start the IPR again or render again.
https://www.dropbox.com/s/w3kiarssx75dgux/displacebug.rar?dl=0
(couldnt upload a zip here)
Message 8 of 9
peter.horvath6V6K3
Got it, thanks. I'll investigate and keep you updated.
Message 9 of 9
peter.horvath6V6K3
I've found the problem, will be fixed in the next release. Thanks.
