C4DtoA eror message
C4DtoA eror message
cpz
C4DtoA eror message
cpz
Hi, I just installed Arnold for Cinema V23, on a Mac- when I click on "help", top left of info dialog says, " failed to read the latest C4DtoA version number", can someone please explain this to me,? thank you
Stephen.Blair
C4DtoA tries to connect to an Autodesk server to get the version number of the latest available version. If there's a newer version available, it will print that in the About dialog.
I just tried, and it worked. Maybe you have an intermittent Internet connection issue, or a firewall?
// Stephen Blair
// Arnold Renderer Support
peter.horvath6V6K3
Actually it's not a network issue, but a problem in R23. There's a python script running to access the server and R23 uses a newer python version (Python 3). The script needs to be updated.
cpz
Thank you, I just installed V23, so this is new to me, appreciate the fast comment-will find out how to download the new script, stay safe
peter.horvath6V6K3
Well, the script embedded into the plugin, so fixing this requires a new release.
cpz
Thank you, Craig
