I have a problem with the displacement and I'm assuming an error.
When I use displacement and there is an object nearby, it is partially not captured by the exposure.
I have attached two examples.
The first picture with 8 cm displacement, the second with 20 cm.
With the cube you can clearly see the error calculation at floor level - only white areas.
Is there a solution to this?
I Use Cinema 4D R20 and the current version of Arnold.
