Arnold transmission C4D in render is black
Message 1 of 13
hi, i have a problem with transmission, i'm trying to have water droplets on a can model, do you know why is black? i turned opaque of on my droplets and have transmission set to max on my material.schermata-2021-01-13-alle-180812.png
Replies (12)
Message 2 of 13
Stephen.Blair
What are the shader settings on those droplets?
I did a quick test in Maya and I didn't get dark droplets with this clear_water standard surface:
clear_water.ass.txt
Just save the file, remove the .txt, and load it with Arnold > Materials > Import
// Stephen Blair
// Arnold Renderer Support
Message 3 of 13
The point is I just did a sphere and a cloner on the subdivision surface and apply on that cloner a simple standard surface with transmission set to max. In maya I don’t have that problem but in cinema 4d I have it. The weird thing is that on the top of the can the droplets are fine, they are simply transparent how suppose to be. I’m frustrated..
Message 4 of 13
lee_griggs
It looks like it is because the drops geo are intersecting the can and therefore are refracting the dark interior of the can?
Other things to consider:
Opaque should be disabled (although this is automatically computed now).
What are the normals like?
Is transmission_ray_depth high enough?
Are the lights visible in transmission rays?
Is caustics (Advanced) enabled?
If that doesn't work, upload a simple scene somewhere.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 5 of 13
Stephen.Blair
And my point is that we don't know any of your settings.
// Stephen Blair
Message 6 of 13
the funny thing is that the droplets on te top of the can are transparent...look ate the screenshot.
the things seems to not change even if I apply another material on the can...schermata-2021-01-14-alle-150223.png
Message 7 of 13
ok update, the problem seems appear whenever i put a ground plane ! but why? i need a ground for my animation....cant escape from this situation...schermata-2021-01-14-alle-151829.png
Message 8 of 13
lee_griggs
Upload the scene somewhere, please.
Lee Griggs
AUTODESK
Message 9 of 13
the C4D file you mean?
Message 10 of 13
here the project ->>>> https://we.tl/t-xb7EK7DaBu
Message 11 of 13
lee_griggs
As I recommended earlier, you need to enable caustics for the drop shader.
Lee Griggs
AUTODESK
Message 12 of 13
i did it but nothing seems changing...
Message 13 of 13
Pham_Nhat
Hey i have solution, you can increase specular a bit in Raydepth render setting. It's work for me
