Alpha Channels not shown/seen through transmissive/refractive objects?
Edwin_Sumalave
Edwin_Sumalave
Does Arnold to C4D currently doesn't support Alpha Channels seen through transmissive/refractive objects? I'm trying to render glass with transparency alphas. I'm trying to get the glass on this image with a transparent alpha so I can add things behind it/between it and background in compositing. ref.jpg
lee_griggs
'Transmit AOVs' should do the trick.
Lee Griggs
Arnold rendering specialist
AUTODESK
FYI - I just learned from a colleague that if you are using a Sky object (for lighting and/or reflections) but you still want the transparency to show properly in the alpha you need to turn the Transparency samples to 0 on your Sky object.
@Rick Morgan
I m getting your answare..Plz explane me. thanks
@Rick Morgan
2 things you need to do: 1) In your transparent material, in the "Transmission" channel check on the "Transmit AOV's" option. and 2) if you are using an Arnold sky object for lighting, set its"Transmission" samples to 0.
THANK YOU!!!! This has been driving me nuts for a few hours!
