Show only
Search instead for
If padding is lower than the recommended, it can cause artifacts. However in your case it should be fine. If you want to get rid of the warning, you have to set the padding close to the recommended value. (Note, that the value in Arnold is probably in meters, while it's in cm on the UI.)
