Using opacity map for aiToon base color??
I am trying to add an opacity map for aiToon base color.
I plugged my opacity map to the transmission weight.
The transparency, however, only works when the specular weight is set to 1, making only specular color visible.
How can I make this work?
lee_griggs
What happens if you disable energy conserving?
Lee Griggs
Arnold rendering specialist
AUTODESK
