Arnold for 3ds Max
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
control objects alpha
2 REPLIES 2
joie
1050 Views, 2 Replies
Hi there;
Coming from Mental Ray, I was used to do things in a different way.
I used to render my scene with regular opaque alpha for hero objects, and zero alpha for background (surface background, like a photography studio background).
But I can't find a way to do this with Arnold.
I know there is a "matte" option in the object's shape, but that forces the alpha channel to be zero, but makes the object completely black too, and that's not what I want.
I want the object to render as normal, but write black alpha channel.
Is that possible?.
Thanks in advance.
Labels (2)
2 REPLIES 2
in reply to: joie
Hey,
I am not sure if you can do this thing in alpha But i can give you a way around,
if you are working with "standardSurface"
  • scroll down a bit in shader tab you will find "AOVs" sub-tab
  • Keep ID-1 (or whichever id you want to use) color to white
  • add id_1 aov to your AOV tab in render settings, you can also rename this Aov name
  • If or if not you renaming that AOV name, copy that name and go to you shader and put that name in "ID 1 AOV (or whichever id you using) "
now you will get you main beauty and as AOV you will get your alpha as you wanted.
Hope this will be helpful for you!!
joie
in reply to: joie
I'm sorry I never answered to you!
I wanted this for a shadow matte shader, which unfortunately doesn't have such ID AOVs you talk about.
I ended up using a surfaceColor shader as a passthrough for the aiShadowMatte one, because that shader allows to control Alpha contribution at render time.
Cheers.
