textures search path not working on a specific drive "R:" when using tx
- Mute
- Permalink
- Report
I've got a weird issue with texture search path.
I have a texture with the following file path: R:/textures/example.jpg
If i put R: in the texture search path it's work (with Absolute Texture Paths off).
When I export the ass, i can see the path is relative.
However if my texture is R:/textures/example.tx, it's not working anymore and the texture is not found.
It's only happening when the drive is "R:". I tried the same manipulation with I:, B:, P: and it's all working well.
P.S: a procedural work fine with procedural search paths R:/, the issue is only for tx files.
The error is the following
// Error: ERROR | [texturesys] aiImage1: Invalid image file "textures/example.tx": Could not open file: t: Cannot open
Could not open file: t: Cannot open //
I also notice, that is my texture path is R:/others/example.tx, then the error change to:
Could not open file: o: Cannot open
t: becomes o:
It's like the disk becomes the first letter of the first folder.
If I select a third folder the errors change too with the first letter of this third folder.
If i create a virtual disk with subst H: R:/, then it's start working again and the texture is sourced with H:
The issue happen only with tx files.
any ideas ?
