Replicate sculptures like Marti' Moreno's.
pproestos
pproestos
@Lee this one is for you... 🙂
I want to create 3D sculptures with Arnold like Marti' Moreno's ones.
https://www.thisiscolossal.com/2011/12/figurative-sculptures-by-manuel-marti-moreno/
I want to use previous method of @Mads to make dissapear the texture
https://answers.arnoldrenderer.com/questions/20386/holes-that-randomly-disappear-with-osl.html?child...
My question is if possible to create a displacement shader that extrudes in direction of the curve of the sculpture...
Anyway if someone can post a tutorial how to do this...
thx again magicians.
lee_griggs
Hi Petros, this looks like a geo instancing case. Maybe this could be a good use for Bifrost instancing? If the camera is not too case you could fake it by adding a repeating texture to the opacity, displacement etc. Maybe @Mads Drøschler has a cool OSL shader for this?
Lee Griggs
Arnold rendering specialist
AUTODESK
madsd
We can create an SDF bolt and use Pflow to instance each SDF shader. Then render Implicit stucture.
Bit like this, here I created the LEGO brick in an OSL shader and distribute the solids pr particle.
You kinda need to go SDF route, as you would end up with a vector displacement for the shader that would take a very large amount of geometry density to render correctly.
Look at TyFlow though, you can distribute the bolts and get what you want with a regular mesh.
They have a facebook page with a ton of scenes you download and the plugin if free for now.
pproestos
that TyFlow... what a tool... 🙂 🙂
