Render has black smears in the alpha while using Motion Blur
osukas
osukas
Im rendering a bird flying with 3dsmax 2024 / Arnold
I have the motion Blur active so the wings looks realistic. My background is empty because I will be inserting it on a footage.
When I insert it, I have black smears around the character, my solution at first was adding the footage in the background, but Im using Aovs in compositing and the diffuse has the black smears.
There is a way to get a clean alpha that doenst get contaminated by the Empty Background in scene?
CiroCardoso3v
Do you see those black smears when you are in comp? Can you show an example?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
lee_griggs
Yes, it would be useful  to know how you are rendering it out (which format) and how you are bringing it into the post-app (premult?).
Lee Griggs
Arnold rendering specialist
AUTODESK
osukas
Got back to the project and found out the issue. (I tested with a Mat to Material shader with white color, and the render was clean with the alpha, no smears)
The model I rendered isnt mine so I checked the shaders, for base color uses a bitmap with alpha, the alpha output is assigned to Opacity. In the Alpha area when you have the Opacity turn OFF, the background of the .png is black.
With the Opacity ON, if you zoomed at the image you could see some black edges around the shapes, with the motion blur activated this edges was making the ugly black smears in the alpha
To fix it I used a ramp to constrast the alpha bitmap, and now the edges in the render are clean
