Render Error by using HDRIEnviron.osl
I render a scene with an HDRIEnviron.osl and an HDRI image.
The first time everything is rendered. If I render again, the rendering process stops with an error message.
What am I doing wrong?
I have the current NVIDIA Driver 452.57 and I have a Quatro RTX 4000.
Thanks for your effort.
Frank
Here is my test scene with 3dsmax 2021.2
ARNOLD.zip
CiroCardoso3v
There are some issues with OSL nodes that will only render once. I also use the HDRI Env OSL and I have that problem, although in my case it doesn't stop the render, it just doesn't show in the HDRI map in the render. There is an update is going to fix that.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Stephen.Blair
Yes, a fix for this will be in a future Arnold update.
// Stephen Blair
// Arnold Renderer Support
