- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm rendering a 2000 frame image sequence, using Arnold GPU rendeering on 3ds max 2021 and the most up to date version of Arnold, After about 350 frames that rendered successfully, I stopped the render to do something else on the same machine. Later, when I restarted the render, arnold started outputting completely black frames, each taking 2 seconds. I examined the render log, and it said: "Fatal GPU error occurred, please restart the host application".
I restarted my computer but the same problem is still occurring. CPU render for this file is taking forever and isn't a viable option. Is there anything I can do? what could be the issue?
Additional information:
My machine is a brand new i7/9700 with 16gb ram and an RTX 2060 super GPU.
This issue only happens in one, quite resource-heavy, scene. Other, simpler files render just fine. The scene contains about a 1M polys, thousands of objects and lots and lots of textures (all of them in TIFF format) but no procedurals, materials are both physical and standard surface. nothing more complex than an editable poly - no volumetrics, fluids, or anything of that kind.
