Maya/Arnold crashes everytime I render
rogermagrinisilva
Message 1 of 11
rogermagrinisilva
Hello, I've been having this issue where my maya/arnold crashes everytime I render. In Maya 2018.5 usually works, but Maya 2020.4 crashes. I've tried reducing the threads to 8, but didn't work also. Rendering CPU.
Replies (10)
Message 2 of 11
Christoph_Schaedl
What does the Arnold log say?
https://linktr.ee/cg_oglu
Message 3 of 11
rogermagrinisilva
Hi, so I've tried creating a log for that problem, but it seems to close and the log file doesn't appear. So I don't have any logs about it.
Is there a way to create a different log?
Message 4 of 11
Christoph_Schaedl
Save the log to disc.
Under Log tick on "File"
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-ge....
Message 5 of 11
rogermagrinisilva
I was using this settings, lemme render now and test it, I'll post it here soon
Message 6 of 11
rogermagrinisilva
Tested it today and it doesn't create any logs
Message 7 of 11
thiago.ize
pleaseWork.* is not a valid filename because it has a * in it. Try pleaseWork.log. Also, is it crashing even if you try to render a simple scene (a sphere and nothing else)?
Message 8 of 11
rogermagrinisilva
so, whenever I try to name the log, it always adds a * to it
Before:
When I click select
I will remove that there. I've also optimized the scene.
and no, it doesn't crash when rendering a normal sphere, maybe it has to do with my heavy scene, close up or xgen. I'm adding an image here of what I'm tryna render.
Message 9 of 11
rogermagrinisilva
adding a .log after
Message 10 of 11
rogermagrinisilva
Message 11 of 11
rogermagrinisilva
I think I've found a solution, the renders are going through now. The subdivision of the head mesh was at 5, so I lowered it to 4 and now it seems to be working, I'll update it here if I have my sequence
