I have been trying to learn how to use the Arnold denoiser for animation in max 2020 and max 2021 but have not been able to follow the documentation provided here:
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Denoiser
which states:
The workflow is as follows:
Step 1 is easy enough being just a checkbox with no other user input required
Step 2 says to ensure that you are rendering out to EXR. So I check the file save box and when prompted, give the name of the output file selecting open .exr as the file type
Step 3. I render the scene (production render) and there is a file in the output folder I specified with the name, MyFileName.exr. But there is no separate file named postfixed by "_Noice_Input" which is what step 3 says I should feed into the input on step 5. And when I enter the single .exr file that was saved by the render operation and specify and output destination for that, no additional file is outputted and I get the following info from the log,
noice 7.0.0.0 [47ab20b9] - the Arnold denoiser
Using 12 threads.
Loading images...
Loading file "E:/3dsmax/renderoutput/Camera_Dan POV Cheat.exr".
Required metadata not found, check that the image was rendered directly with Arnold.
Denoising complete.
Step 3 also states, “Alongside your beauty file (id enabled), …..” which suggest to me that I should add the beauty pass (RGBA) with ID enabled? Not sure how to do this. I did add the following AOVs using the AOV manager (RGBA, diffuse direct, diffuse indirect, specular direct, specular indirect), but as I mentioned above I got no denoised output.
Can anyone provide any insight into what I am doing wrong and how to use the denoiser with Arnold in Max 2020 or 2021?
Seaprately, for a single frame. I did try the Denoiser Noice under the Imagers tab of the Render setup, which doubled the render time, but definitely reduced noise for a single frame. But since I will ultimately need multiframe animations, I need to get the .exr workflow via the Denoiser Tab going.
Thanks in advance for any guidance.
Solved by Stephen.Blair. Go to Solution.
I just tried it again to be sure, and there was nothing special to do.
Enable Output Denoising AOVs and render an EXR. I got the _Noice_Input.exr
I would start by checking the Arnold log (Verbosity Level = Info)
The highlighted part of my log shows that the denoising AOVs are part of the output.
Thanks Stephen for your response. In fact, when I first removed the AOV's I had created for the Production render and then followed the simple steps outlined in the guide, I did get the _Noice_Input.exr output and the denoising step went perfectly. So my mistake was thinking I had to add AOV's in addition to those automatically created by Arnold. And apparently manually adding AOV's pre-empts the creation of _Noice_Input.exr output. Sorry, my mistake. Also, the denoised output looks very good. Thanks again for your help.
